Carrier bearing; DORMAN vs SKF?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PA452, Jul 21, 2014.
  1. Jul 21, 2014 at 6:41 PM
    PA452
    PA452 [OP] Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    Rock Auto has both. The SKF is nearly 3x the price of the DORMAN. In searching I'm finding few references to the SKF bearing. I did find someone who said they were on their second cheap bearing though.
    Is SKF worth the extra cost?
    Boneretreiver likes this.
  2. Jul 21, 2014 at 6:55 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I would absolutely NOT put a Dorman bearing on your truck. I bought one through Rock Auto, it was cheap but they had a great warranty. I got about 300 miles out of the first bearing before it started squealing. Rock Auto was great, they warrantied it and sent me another. I got almost 500 miles out of the second one. I made sure everything went together the correct way both times. Rock Auto gave me a store credit instead of going for a third. I ended up buying an OEM bearing to the tune of $150, 3x the cost of the Dorman.
    Here's an interesting fact though, I had some slight vibrations and a shutter at certain speeds with my old OEM bearing, they all went away with both Dorman bearings and came back when I went back to OEM. The OEM I believe is a better bearing but the rubber around it is shit. The Dorman is the opposite.
  3. Jul 21, 2014 at 7:00 PM
    PA452
    Western PA
    Thanks for the reply. I was kind of leaning toward trying the SKF anyway. I think you've pushed me over that edge, although I may look into a factory bearing too.
  4. Jul 21, 2014 at 7:10 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    SKF makes a very good bearing. They are expensive because they are very high quality. I used to repair large rotating machinery such as electric motors which run at high RPMs in high heat with heavy loads. SKF was one of the best bearings available for these applications. I suspect they would do quite well on your truck too.
    If you get the bearing number (not the store part number) you might be able to find a local bearing dealer that you can buy it from cheaper than an auto parts supplier. I rebuilt the pump on my Yamaha Waverunner a few years ago and bought bearings locally instead of buying the "Yamaha" bearings.
  5. Jul 22, 2014 at 7:12 AM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    Bearings are like tires IMO, you get what you pay for. No Dorman for me, I always bought Timkens when I could get them for the application.
  6. Jul 22, 2014 at 7:21 AM
    gearcruncher
    Canadain bumper technician
    There was an earlier post from a member who said he replaced his bearing with one from a Ford Ranger as it uses the same inside diameter as the Tacoma . I am assuming that Spicer also makes the driveline for Ford . With this said , apparently the rubber bonding on the Ranger bearing is solid and not flexible like the Tacoma . This replacement Ford bearing could be a cheap an easy fix to a well known Tacoma issue .
    If I find the post again , i will edit and link to it .
    In the mean time , SKF all the way
  7. Jul 23, 2014 at 6:49 PM
    PA452
    Western PA
    Thanks guys. I went with the SKF, it should be here Saturday.
  8. Jul 23, 2014 at 6:52 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Subd for results :D
  9. Jul 23, 2014 at 7:01 PM
    PA452
    Western PA
    I'll be sure to post updates. :)
    The u-joints were shipped separately, they're scheduled to arrive Thursday. I'm hoping to work on the two u-joints that I can replace tomorrow night some if I can get out of work early enough, then hopefully finish the job Saturday or Sunday.
  10. Jul 24, 2014 at 8:44 PM
    PA452
    Western PA
    Still waiting for the SKF bearing, but tonight I pulled the three u-joints and the yoke in front of the CSB bearing. Turns out that bearing was probably alright and didn't need replaced, but that's OK, it's getting replaced now.
    Two of the u-joints were fine I think too. Only the one in the rear was clearly in bad shape.
  11. Jul 24, 2014 at 11:07 PM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    I'm curious if the skf bearing fits because it also cross references with the 1st gens
  12. Jul 25, 2014 at 8:59 PM
    PA452
    Western PA
    Sure hope so. I should find out tomorrow.
  13. Jul 29, 2014 at 1:01 PM
    Hans Moleman
    Bay Area, CA
    Any updates on the SKF bearing? I need a new one too and would like to order this one if it fits.
  14. Jul 29, 2014 at 1:19 PM
    Pugga
    Massachusetts
    What did you end up getting for u-joints? I ordered Moog for mine and out of the 3 I ordered, 1 actually fit.
  15. Jul 29, 2014 at 2:50 PM
    PA452
    Western PA
    It arrived late Saturday and I got it on that night. Seemed to fit fine. I went for maybe a 30 mile ride Sunday, no issues so far. The shuddering and noises I had before are gone.
    I should say though, I think my problems were entirely with just one u-joint. The other two were fine, and once I was able to get a better look at the CSB and then subsequently compare to the new one once mounted, I think the old one was probably fine. I can move the shaft inside the new one about as much as the old one I think.
  16. Jul 29, 2014 at 2:51 PM
    PA452
    Western PA
    Spicer greasables from Rock Auto. All fit, I'm happy with them so far.
  17. Jul 29, 2014 at 3:10 PM
    Hans Moleman
    Bay Area, CA
    That's sounds great. I'm going ahead to order it.
    I'm also replacing my u-joints with Spicer Life series
  18. Jul 29, 2014 at 3:13 PM
    PA452
    Western PA
    You may already know this, but just in case the Spicer "Life" means sealed and lubricated for the life of the u-joint. If you want zerks don't get the Life parts. I almost got the Life ones until I found that out.
  19. Jul 29, 2014 at 3:18 PM
    Hans Moleman
    Bay Area, CA
    beavis87 likes this.
  20. Jul 29, 2014 at 7:45 PM
    PA452
    Western PA
