Carrier bearing drop and Vibrations
Discussion in 'Suspension' started by Canadianboy, Jan 11, 2010.
  1. Jan 11, 2010 at 5:36 PM
    Canadianboy
    Canadianboy [OP] Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    I just wanted to make a post about my lift, vibrations and what worked for me to fix the vibrations.
    So, I have a 09 Double cab Sport 4x4 with automatic.
    For a lift I have a stage 3 Icon lift. Up front I have the Icons set at 2.25" and the 1.5" aal in the rear.
    Right after I installed the lift I had a noticeable vibration around the 5 - 10 mph range that I could feel through the floor board.
    I ordered the Carrier Bearing drop kit from Toytec, and this 100% fixed my driveline vibrations. I have no vibrations now and
    the truck drives like a dream.
    I think the more you lift the rear of the truck, the more noticeable the vibration will be and the more difficult to remedy.
    Anyways, thats what worked for me. Cheers.:)
  2. Jan 11, 2010 at 5:51 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    yea your telling me....i put 5100's on 2.5 up front and drove like 10 days with no vibes...then i added the 2" aal in the rear and now it sucks....bad vibes around 20-25 40-45.....did the carrier bearing drop and nothing.....im gonna try the axle shims next.....
    anyone else have any solutions???????
    oh and its a 09 or
  3. Jan 12, 2010 at 4:18 PM
    nolanspawn
    nolanspawn Work In Progress
    Layton, Utah
    2011 Tundra Crewmax
    Corsa Exhuast, AFE Intake
    I had vibrations even after the carrier bearing drop kit from Toytec. So I ordered some shims 3 degree axel shims and it fixed the problem for good.
    My setup. Icons RR all around, TC UCA, allpro 3" leaf pack.
  4. Jan 12, 2010 at 5:46 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    where the axle shims your ordered from toyotech?
    dam i got them same rims.....i lovin it
    same n fab bars i have as well.....
    dam i need your hood
  5. Jan 12, 2010 at 7:47 PM
    nolanspawn
    Layton, Utah
    2011 Tundra Crewmax
    Yep, they were Toytec
  6. Mar 25, 2011 at 8:02 AM
    OH9
    OH9 Member
    Colorado
    09 dbl cab auto stock
    I have a 09 dbl cab auto but stock and I have the same vibrations.
  7. Mar 25, 2011 at 8:04 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    Wow old thread...........
  8. Oct 16, 2011 at 9:48 AM
    05bctacoma
    05bctacoma Member
    Keith
    chilliwack BC
    05 Tacoma
    NIL
    I have a 2005, DC, 6' box, SR5, 4X4. I purchased the truck Dec '04, now has 151,000 kms and have only replaced both front wheel bearings (@ $1200 / side ouch). Now that the stock tires are finally worn out (I run 2 sets for the seasons) I decided to level it out and rise it an inch... So I bought a 3" lift (1" rear spacer) with a differential drop. I also picked up a complete TRD suspension from a friend who upgraded with an OME kit.... mine had the soft springs...missed the recall.
    I installed the kit over a 2 day period. I Put the new rear leafs (1' spacers) TRD shocks and drove it to work for the next four days. I did not noticed any difference in the handling.
    Now the problem.... I installed the new TRD shocks and springs with the front lift (top of the strut type)....and installed the differential drop. The install was easy enough and though that I had missed out for 6 years. Until I took it out of the driveway... then the regrets begin.
    I get a vibration at 60km/hr. So I put the truck in 4WD and it disappears? I switch back to 2WD and it comes back??
    I google it and lear of the OME 1/4 CB drop kit. I install that and still the same. I try a piece of 3/4 steel stock as a spacer and get the same. I remove the diff drop and still the same.
    I'm going to try 1" and then 1&1/2" for a solution!!!
    I have not tried shims yet!!!
    My biggest question is .... is it a differential concern???
    Should I remove the lift and go with the TRD upgrade alone... and see what happens?
    It does not seem right as there are a lot of Tacomas lifted and this model is into it's 7th year!
    I've put 300kms since the lift. I have supported the rear axel on stands and ran it in gear up to 80km/hr with no noise??? I lifted the front and spun the front tires by hand and got no noise nor felt anything odd? I do not have 4 axel stands to try 4X4 while in the air???
    I'm at a loss!!!
    Please anyone restore my faith in a Toyota... I love my Tacoma.
  9. Nov 2, 2011 at 11:49 AM
    upcountry
    upcountry Active Member
    Seattle
    07 Tacoma
  10. Nov 2, 2011 at 11:53 AM
    upcountry
    Seattle
    07 Tacoma
    http://www.streetacos.com/Products.html
    Carrier Bearing Drop 2005 & newer Tacoma 4" & lower REAR lift
    Drops the bearing 1-1/2" to kill drive line vibrations on trucks 4" and lower in the rear. The top tower utilizes a factory hole in the cross member above to help rid the area of unwanted flex.
    Quality hardware included and painted black.
    Bracket $62.21
    Shipping $16.00
    Total $78.21
  11. Nov 2, 2011 at 7:04 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
  12. Nov 4, 2011 at 7:15 AM
    upcountry
    Seattle
    07 Tacoma
  13. Nov 4, 2011 at 10:29 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    do you mean 2.25" of lift from the coilovers of 2.25" of thread showing?
