Carrier Bearing Drop Bracket
Discussion in 'Suspension' started by VolsGuy, May 29, 2013.
  1. May 29, 2013 at 7:02 AM
    VolsGuy
    VolsGuy [OP] New Member
    Joel
    Colorado Springs
    '13 Tacoma TRD Off-Road
    Hello all!
    I've got the typical off-the-line shudder up to about 15 mph, where it disappears. I've installed the OME CB drop kit, to no avail.
    I've also got the axle shims installed. I'm now looking into the Streetacos 1.5" CB drop bracket. So far, I've seen only one gentleman it didn't wok for. Is there anyone else out there who didn't see vibration improvement from this bracket?
    Thanks!
    '13 TRD off-Road DCSB
    3" Toytec Coils w/AAL
  2. May 29, 2013 at 10:02 AM
    VolsGuy
    Joel
    Colorado Springs
    Just spoke with Brian of www.streetacos.com. Seems like he's got a great business going...and quite a bit of job security for those of us with lifts. Going to put my order in today...wish me luck!
  3. May 29, 2013 at 6:48 PM
    coseng
    coseng Well-Known Member
    Grove City, PA
    2011 TRD DC
    OME 885x front, Dakars rear, LR UCAs, ECGS bushing
    I have Dakar rear springs, three degree shim, and beefed drop bracket. I am 95% vibe free. I still get a vibration when cresting a hill and leaving off the throttle. It happens when the drive shaft goes from being loaded uphill then has a brief moment of slack before being loaded going downhill. The vibe occurs when the driveline is slack.
  4. May 30, 2013 at 3:11 AM
    661prerunner
    661prerunner Well-Known Member
    Santa Clarita
    01 prerunner
    FabTech C/Os, Solo tubular UCAs (on order)Solo spindles(not installed) Glassworks front and rear, made by me Rocksliders, Premier Navi,
    I recent bought a ST drop bracket and installed it with a bad carrier bearing. I still felt less vibrations despite the bad bearing. I was very surprised. I still have yet to drive my truck with a good bearing since its still at the shop. But I imagine it will be better
  5. May 30, 2013 at 4:06 AM
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Icon extended travel coilovers and rear shocks, Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Timbren Bump stops ,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
    I have had mine for over a year and it took care of the shudder and most of the vibs. I still have a very slight vib at 25mph but you really can't feel it with the tires. Over all great product.
  6. Jul 23, 2013 at 7:56 PM
    joelt
    joelt Well-Known Member
    Joey
    Anchorage
    '17 TRD Off-Road
    Finally got the kit from Brian...shudder GONE!
  7. Dec 30, 2013 at 1:42 PM
    bw4706
    bw4706 Well-Known Member
    Illinois
    09 Toyota Tacoma DCSB
    Bilstein 6112's , Eibach Coils,Hankook Dyna Pro MT 265/75/16, SPC UCA's, General Spring HD leaf packs, De-Badged, Ranch Bed Cap, Mag Light Seat Mount driver and passenger, Mini Mag Console Mount,Hard wired GPS, LED's in and out, MB TKO Wheels, After market grill, Heated seats, Diff breather relocation mod, LED Under Hood Lighting, LED Bed Lights, Aux. LED Reverse Lights, 30" L.E.D. Light Bar, Redline Tuning Hood Struts & EZ Down Tailgate. 6 Circuit Aux. Fuse Panel W/Circuit Breaker. Front & Rear Facing DVR cameras, High Lift Jack Bed Rail Mount. Clazio Leather Seat Covers. All Pro Heavy Duty Rock Sliders, 4x4 illuminated switch mod, Ignition converted to Push to Start. Bushwacker fender flares, Cali Raised side projector ditch lights. Cali Raised L.E.D. fog lights. 3 x 3 L.E.D. rear spotlights , Anzo headlights and taillights.
    Just had my toytech bilstein 5100 lift with 2" AAL's installed. I have the slightest vibration at take off only. Just ordered the 1 1/2 carrier bearing drop bracket from street taco. Hope it solves my problem.
  8. Feb 21, 2014 at 12:42 PM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    bw4706 did it solve your vibs?
  9. Jul 30, 2014 at 4:21 PM
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    What happened?
    Vibes gone now?
  10. Jul 30, 2014 at 5:44 PM
    lsutiger1
    lsutiger1 Well-Known Member
    Wilmington, NC
    2017 BLACK TRD OFF ROAD DCSB
    3inch lift,285/75/16 on method 301's
    I installed the ome carrier bearing drop kit and mine are gone! Guess all trucks are different!
  11. Aug 21, 2014 at 7:31 PM
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    I just installed my OME Carrier Bearing Drop. What do you torque the bolts to?
  12. Aug 22, 2014 at 10:52 AM
    lsutiger1
    Wilmington, NC
  13. Aug 22, 2014 at 10:59 AM
    lsutiger1
    Wilmington, NC
    On the second Gen forum there is a sticky that has all the torque values.
  14. Aug 22, 2014 at 11:40 AM
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Thank you
  15. Aug 23, 2014 at 4:35 AM
    williams63
    williams63 Well-Known Member
    chili
    nh
    2011 dblcb
    boss-c/o, boss rear leafs
    did you put axle shims in also or just the ome cb drop? I have the wheelers 3leaf like you with the overload in. slight shutter at take off. put the ome cb drop in and made it worse.
  16. Aug 29, 2014 at 9:20 AM
    lsutiger1
    Wilmington, NC
    No just the ome cb drop.
  17. Aug 29, 2014 at 10:17 AM
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    I think I might need Axle Shims but want the kind that doesn't require pulling out the Center Pin.
  18. Oct 3, 2014 at 5:29 AM
    RosenbeD
    RosenbeD Member
    Dave
    Holland, MI
    Silver SR5 ACC cab 4x4
    Bilsteins set at 1.75 1.5 AAL Wheels and tire 20% window tint
    I am reaching out to you guys that have done this and for your advice. I have 2014 with Bilsteins set at 1.75 and a 1.5 AAL with overload left out in the rear. My vibes are between 25-45mph. When I look at the drive shaft it looks level and straight. So with my small lift I am trying to decide whether to try OME drop kit which seems cheap but the right amount of drop or do I go with Street Taco bracket which is beefy yet might be too much at 1.5 in drop???
  19. Oct 3, 2014 at 5:53 PM
    parkp81
    parkp81 Well-Known Member
    Fil
    Southern California
    I dropped mine using 10mm washers (not the thin fender washers, they have ones that are the same width, but thicker). I dropped mine starting at 1/4" and added a washer until I reached 5/8" worth of washers and the vibe is pretty much gone. I may add one more washer, but right now its good.
  20. Oct 4, 2014 at 5:11 AM
    RosenbeD
    RosenbeD Member
    Dave
    Holland, MI
    Thanks for the advice. I decided to first try OME kit since it is inexpensive at only $12.99. Based on your success with washers I think the OME will work fine. I will report back after install.
