Carrier bearing drop help
Discussion in 'Technical Chat' started by 09tacoLI, Jul 15, 2009.
  1. Jul 15, 2009 at 10:19 PM
    09tacoLI
    09tacoLI [OP] Well-Known Member
    long island ny
    09 off road
    Shrockworks sliders,Shrockworks Front bumper,Warn 9.5xp winch,Toytec Ult.3in,Total Chaos UCAs,AP expo Rear, Fox remote resi shocks Bud built skids,Piaa 7in,Piaa yellow plasma Off road lights.
    I have an 09 trd 4x4 with a toytec 3inch lift. When the lift was put on we weren't sure how to put the shims in so we didnt put them in. I have vibes when I start to drive. I just installed the old man emu C/B drop and now it sounds like the rubber boot on the C/B is rubbing on the driveshaft. If anyone has trouble shooting tips or a fix I could use alittle help here.
  2. Jul 16, 2009 at 8:42 AM
    09tacoLI
    long island ny
    09 off road
    Anybody out there Bump
  3. Jul 16, 2009 at 8:44 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Post pictures of your setup. It's pretty hard to mess up the carrier bearing drop installation. There may be something funky going on that'll be clear once we see it.
  4. Jul 16, 2009 at 8:47 AM
    09tacoLI
    long island ny
    09 off road
    Ill post up some pis
  5. Jul 16, 2009 at 8:48 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    we are going to have to install the shims i know its a drive let me know when Dave T
  6. Jul 16, 2009 at 8:49 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You should only need the shims if there are vibes....If he has a rubbing sound, Im guessing maybe a heat shield or something near the tank is rubbing.
  7. Jul 16, 2009 at 8:55 AM
    David Tarantino
    N.J.
    08 tacoma
    i think he did the diff drop to try to stop the vibes
    and now has the rubbing sound and still has the vibes
  8. Jul 16, 2009 at 8:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Gottcha! :)
  9. Jul 16, 2009 at 8:58 AM
    mjp2
    NJ
    Ahhh! Diff drop vs. carrier bearing drop. Yeah, we really need those pictures. :)
  10. Jul 16, 2009 at 8:58 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2.
  11. Jul 16, 2009 at 8:59 AM
    David Tarantino
    N.J.
    08 tacoma
    iam sorry we did the diff drop here at the shop
    he did the c/b drop
  12. Jul 16, 2009 at 9:01 AM
    mjp2
    NJ
  13. Jul 16, 2009 at 9:05 AM
    David Tarantino
    N.J.
    08 tacoma
    ok so this is what was done we did a 3inch lift with a diff drop
    we did not install the shims
    he installed a c/b drop thinking it was going take fax the vibes
    and now has rubbing sound
    iam thinking if we install the shims and remove the c/b drop
    all should be ok????? or just install the shims????
  14. Jul 16, 2009 at 9:28 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It depends on what he is rubbing on. Need to identify the rubbing before throwing parts at it.
  15. Jul 16, 2009 at 1:55 PM
    09tacoLI
    long island ny
    09 off road
    It sounds like the rubber boot thats in the pic.
  16. Jul 29, 2009 at 11:16 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    what happened? Did you solve the problem?
  17. Aug 30, 2009 at 9:03 PM
    09tacoLI
    long island ny
    09 off road
    Forgot about this thread its all fixed Davidtarintino put the shims in the rear for me and the problem was fixed right away he helped me out alot with this whole lift process.
  18. Aug 30, 2009 at 9:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good to hear! David is a hell of a guy. :)
  19. Aug 31, 2009 at 3:57 AM
    David Tarantino
    N.J.
    08 tacoma
    AAAH thanks guys :eek:
    good to here it worked :D
  20. Nov 17, 2009 at 7:41 PM
    Jones'R
    Jones'R My
    Niagara Falls
    08' SR5
    3" Lift
    How thick are these shims roughly. I have a 3" lift and the same problem. I can machine some of these this week and install them. 1/4" sound right ?
