Carrier bearing drop?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Alament92, Mar 26, 2015.
  1. Mar 26, 2015 at 4:34 AM
    Alament92
    Alament92 [OP] Well-Known Member
    Austin
    Arizona
    2012 Tacoma TRD Sport
    HID's, Rancho quicklift, 295/75/16 Nitto Terra Grapplers, Method Race Wheels, K&N CAI, LED interior dome, map, license plate lights, 30 inch Avec LED light bar, Anti-dark hood lighting kit
    At what point do you need to drop the carrier bearing? I have a rancho quicklift setup in front with about 2 inches of lift, and am stock in the rear. I am looking to lift the front more soon, as my truck just barely sits level and I like the front higher look. What point does it start messing up the carrier bearing? Had an old Ranger with a lift and that thing went out all the damn time and was a pain in the ass. Really don't wanna deal with it on this truck too
  2. Mar 26, 2015 at 4:47 AM
    Large
    Large Red
    I would only use a CB drop if you mess with the rear.
  3. Mar 26, 2015 at 4:52 AM
    Alament92
    Austin
    Arizona
    Ok I was under the impression that if you lift the front and not the back then it messes up the angles. And if you lifted both the same it would stay in line but I suppose I wasn't thinking that through right
  4. Mar 26, 2015 at 11:14 AM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    Here's the way to think about this.
    When you raise just the front, since the body doesn't bend, you are pivoting it around the rear axle in the back. Since the carrier bearing is in front of the rear axle, it is being raised a bit, and since the rear axle is not moving, the angle is definitely changing. For the sake of discussion, say the carrier bearing is about 1/3 of the way to the rear axle, 2/3 of the way to the front. This means that for every 1" you raise the front by itself, you raise that carrier bearing by 1/3 of an inch. If you raise just the rear, then for every inch you raise, the CB raises by 2/3 of an inch. If you raise both by the same amount, obviously the CB raised by that same amount since it is still attached to the body/frame.
    The greater the angle between two shafts connected by a single universal joint, the more irregular the motion becomes. Ideal angle is zero degrees. You can stand fluctuation up and down on bumps. Not so much on straight and level driving. That leads to vibration.
    If you measure accurately, to determine exactly how far the carrier bearing is from the front and rear axles (my number was just a guess to make the explanation work) then you can figure out what you need to do. But if you raise anything, the optimal path would be to lower the CB by the amount calculated as above. Then you stay in the stock configuration. It might be that you can get by without dropping the CB, but you are certainly increasing the angle, and vibration is not that far away. And might even already be present, you just don't yet notice it.
    I've built a couple of hot rods where we dropped in a foreign engine/tranny. That makes for a LOT of fun. Sometimes it will only fit if the tailshaft of the tranny droops a bit. There's an unwanted angle. A Cardan joint (i.e. a double u-joint or something similar as used in CV joints) solves this, but they are not as cheap. That's why they call them CV (or constant-velocity). They don't exhibit that irregular speed on one side as the other rotates while the shaft is at an angle.
    That whole thing on the Taco seems to be an ill-conceived idea, one that was created at the last minute to address a problem that was overlooked until right at the last minute.
    A one-piece drive shaft has the same problem if you lift, since you are screwing with the angle at the front and at the back at the same time.
    stvhwrd likes this.
  5. Mar 26, 2015 at 3:07 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    I don't have a carrier bearing drop. I have a 1.5" aal with a small degree shim in the back and coilovers in front set just under 3". I have zero vibes or issues. I also had Bilstein 5100s on my old 2005 Tacoma set at .85 and then at 1.75 and no rear lift. Never had issues with it either and i didn't have cb drop.
  6. Mar 26, 2015 at 3:54 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    LOLOL are you seroius?
    Raising the front alone does NOTHING to actual driveline angles in the rear. It simply moves the driveshaft a little further off the ground. as the truck is now sloped more upwards at the front. THE ONLY driveline that is touched by raising the front are the angles of the front CV joints at the hub and front diff.
    By your logic simply putting blocks of wood under the front tires or going up a hill would mean the rear driveline angles are changing.
    Nice try though, love the troll logic.
    Stryker420 likes this.
  7. Mar 26, 2015 at 5:41 PM
    RobertHyatt
    Robert
    Birmingham AL
    Sorry, but try again. If you raise the front by N, you raise the midpoint by N/2 and the point above the rear axle by 0. Believe what you want, but the pinion angle WILL change when you raise any part of the truck, because the driveshaft does not move, but the body of the truck certainly gets higher. Unless, perhaps, if you cut the body between the bed and cab of course.
    Didn't say a THING about a block of wood under the front tires, numb-nuts. I said "raise the body with respect to the driveline". If you put something on TOP of the front axles, so that the front bumper is higher, yet the axle is the same, you just changed the driveline angle. There is NO way around it. You simply need to read and THINK first. One end of the drive-line is the rear axle that does not move. When you move the engine/tranny that is attached to the frame, WHAT happens to that carrier bearing attached to the body in the middle of the back? Is it NOT going to raise somehow? Body goes up, CB goes up. Angle between driveshaft and pinion and carrier bearing will change. Angle between CB and tranny won't change, but the other side WILL. That will cause vibration. Whether it is noticeable or not is another issue, but it will be there the further you depart from 0 degrees.
    Feel free to give me a simple geometry lesson on how you are going to shift the body but leave the wheels on the ground, and not see that angle shift. It certainly will be far less significant than when raising the back, but it is still there.
  8. Mar 26, 2015 at 5:42 PM
    RobertHyatt
    Robert
    Birmingham AL
    How, EXACTLY, do you raise the rear axle? Bigger tires? That's not a "lift kit". Rear axle remains at same distance from ground unless you change wheel size. Not so the carrier bearing as you raise any part of the body.
  9. Mar 26, 2015 at 6:46 PM
    ajohnson225
    ajohnson225 Well-Known Member
    Austin
    Baton Rouge
    Silver 05 DCLB Sport
    3" toytec lift, 285/70/17 trail grapplers, 17" ballistic offroad, flowmaster 40 delta flow, TRD CAI, debadged, pioneer touch screen, 2 kicker 10" on 1100 watt hifonics, 30" light bar, 15% tint front 20% tint back, interior LED's, all bulbs changed to LED's, LED pod reverse lights
  10. Mar 26, 2015 at 6:55 PM
    Big Tea
    Big Tea WOOOOOOO!!!
    Chesterfield, VA
    08 TRD Sport DCSB 4x4
    It's pretty simple actually, just have to measure the angles at the transmission and at the carrier bearing, if they aren't pretty damn close, you'll need to add a shim. If you do that make sure you also measure the angle at the rear axle to make sure you are still within reasonable tolerances.
    Watch this (lengthy) video that explains it quite well:
    http://youtu.be/f1m-Fh5kiRU
    Mud_Tech and gulzeb like this.
  11. Mar 26, 2015 at 7:15 PM
    Brjw
    Brjw Well-Known Member
    Brian
    Forest Grove, Oregon
    Lol what?
    The pinion angle may change if you are using level ground to measure the angle, but that is a useless number. That isn't pinion angle by definition. None of that matters. By your logic, pinion angle would increase as you park the truck on an incline. You should be measuring the angle between the pinion flange and the driveshaft. That does not change in the rear from lifting the front. All rear angles will stay the same relative to the frame and drivetrain.
    It is like you aren't understand that when you lift the front axle, the rear axle DOES move. It would rotate pinion up a very small amount. Thus the angles all remain the same between pinion, carrier bearing etc.
  12. Mar 26, 2015 at 7:19 PM
    Brjw
    Brian
    WHAT?
    Neither is a lift. I don't know the relevance to this statement but technically a different diameter wheel makes no difference to changing the axle height from the ground, the overall diameter of the tire does. You know, the big rubber part around the wheel.
    And neither makes a damn bit of difference to pinion angle.
  13. Mar 26, 2015 at 9:15 PM
    nd4spdbh
    SoCal
    dude, get your shit checked, you are ALL sorts of wrong. By lifting the front like stated only the front suspension angles change, THATS IT. the engine, frame, trans, transfer case, rear driveshaft and rear axle all stay the EXACT FUCKING SAME relative to eachother, thus THERE IS NO WAY rear driveline angles could change. The only time rear driveline angles change is if you move the motor / trans / transfer case up or down within the frame, CB up or down relative to the frame, or rear axle up or down relative to the frame.
    the below response is perfect....
  14. Mar 26, 2015 at 9:33 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    I think the part you are missing is that the rear axle is hard mounted to leaf springs which are hard mounted to the frame so when you lift the front end the entire chasis and everything attached to it simply tilts up, frame, leafs, axle all tilt up with it therefore there is no change to the pinion angle. The only way the pinion angle would rotate as you are describing is if the rear axle was not mounted to the leaf springs.
    ChillyBear likes this.
  15. Mar 26, 2015 at 9:50 PM
    mattsowell
    mattsowell Ridiculously lazy member
    kamloops, bc
    2010 Tacoma TRD DC SB sport debadged
    no seatbelt chime, stubby antenna, 5100's front and back with AAL, offset rims with Dura-Trac rubber, weathertec mats, Image Dynamic sub with 5 channel Amp and Kenwood Deck with steering wheel control, PIA bulbs, K&N air filter, ARB Delux front bumper
    this
  16. Mar 26, 2015 at 10:12 PM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
  17. Mar 26, 2015 at 11:55 PM
    Alament92
    Austin
    Arizona
    So then when is a carrier bearing drop needed then?
    dirtnsmores likes this.
  18. Mar 27, 2015 at 5:23 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    X2. He fills my head so full of fuck when I read his posts, it's pretty comical.
  19. Mar 27, 2015 at 5:26 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    only to try to make the angles ideal again, to reduce excessive wear or vibration from a more extreme angle, should you lift the rear
  20. Mar 27, 2015 at 5:29 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    no to this.
    when you raise just the front, the front cv's get a more extreme angle...
    but that is it
    when you raise the front, the engine, tranny, frame, and driveshaft all go with it, keeping all prop shaft angles identical.
    you may have been trying to say something else, but what you did say is all sorts of incorrect.
    only if you raise the rear, and the body of the truck in relation to the rear axle changes distance, only then do you have new prop shaft driveline angles.
