Carrier Bearing failure - 4K miles
Discussion in '3rd Gen. Tacomas (2016-2023)' started by backcountryj, Dec 22, 2017.
  1. Dec 22, 2017 at 10:30 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    ermahgerd, yer so deeerrrmmmbbb
  2. Dec 22, 2017 at 10:48 AM
    backcountryj
    backcountryj [OP] Pending Approval
    Jonathan
    GA
    Thread title updated to be more accurate.
  3. Dec 22, 2017 at 11:01 AM
    DPT852
    DPT852 Well-Known Member
    Dan
    Connecticut
    2017 BR TRDOR
    My carrier bearing has been puking like that from brand new, albeit not quite as bad. My assumption in the first few thousand miles was that it was just excess grease being purged after assembly and finally getting hot enough to lose some viscosity.
    If this solves your problem I would much rather replace with a serviceable unit, all these sealed bearing surfaces keep maintenance time and costs down (all important when the services are free) but at what expense to the lifespan of parts?
  4. Dec 22, 2017 at 11:15 AM
    backcountryj
    Jonathan
    GA
    I don’t expect this replacement to solve my problems. Perhaps a temporary bandaide, but doubtful it will be long term. I think the clunk I’m hearing, and feeling is the crap transmission rapidly dumping a gear at the last second.
    DPT852[QUOTED] likes this.
  5. Dec 22, 2017 at 3:21 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    So, what color’d ya get?
  6. Dec 22, 2017 at 4:46 PM
    backcountryj
    Jonathan
    GA
    The Highlander?
    It’s a silver 2018 LXE. I am now the envy of all the soccer moms in my neighborhood.
  7. Dec 22, 2017 at 4:58 PM
    BillyToy
    BillyToy Well-Known Member
    PNW
    2017 Tacoma TRD Pro 6MT
    The beauty of the Highlander: it can only be totalled by another Highlander.
    BigDinTexas and th3118 like this.
  8. Dec 22, 2017 at 5:02 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Why would they bother to check if they were going to lengthen it anyway?
    Not doubting you; just seems inefficient.
    inksin likes this.
  9. Dec 22, 2017 at 5:30 PM
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    It's a standard at the shop I went to, and maybe an industry standard to check the balance of the shaft before apparently just to be sure that there isn't a serious deformity in the shaft that would cause the new welds to fail. I guess this is because I came in complaining about vibrations and issues so they do it to be extra safe, even though it was a new shaft on a new truck.
    splitbolt[QUOTED] likes this.
  10. Dec 22, 2017 at 5:30 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    They just put it into a driveshaft stretcher
    Skydvrr likes this.
  11. Dec 22, 2017 at 5:47 PM
    stevotivo12
    Stephen
    Gotcha! I don't actually work there, but as I understand it it is a standard at the shop to check balance before and after when a customer is complaining about vibrations and driving issues just to check the integrity of the part. I don't know much more about it than that but I do know I went from having driveline vibrations to not having them thanks to their work!
  12. Dec 23, 2017 at 11:19 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    My heart swells with pride
    boynoyce likes this.
  13. Dec 23, 2017 at 12:26 PM
    Nick13
    Nick13 Well-Known Member
    Dominic
    2017 sr
    Op, was the noise u heard a harmonic sound around 45-50mph?
  14. Dec 23, 2017 at 2:19 PM
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    You are hearing the diff howl
    shakerhood likes this.
  15. Dec 23, 2017 at 6:11 PM
    #35
    backcountryj
    Jonathan
    GA
    That’s one way to describe it...
    As I mentioned before, I suspect the carrier bearing failure to be an unrelated issue to the ‘clunk’ I’ve heard and felt when coming to a stop. As well as unrelated to the rear diff howl. They may have some impact on each other, but I don’t expect either issue to be permanently resolved when I get my truck back. Hopefully I’m wrong.
  16. Dec 23, 2017 at 6:34 PM
    #36
    Nick13
    Dominic
    2017 sr
    Ok I misunderstood, thought dealer said carrier bearing was causing both. I have the harsh thump on downshift first couple times in cold mornings along with the other noise. May be different for me as I am only a lowly 4cyl sr also
  17. Dec 23, 2017 at 6:38 PM
    #37
    Nick13
    Dominic
    2017 sr
    Hope you enjoy the new highlander the stealer is going to just know you have to own now that you drive it.
    backcountryj[OP] likes this.
  18. Dec 23, 2017 at 7:05 PM
    #38
    backcountryj
    Jonathan
    GA
    They never outright claimed the carrier bearing was or was not the source of the issues. But simply that that was an issue they found.
    I’m skeptical, but I’ll let them replace it. I don’t see how the carrier bearing could have any impact with such an abrupt and harsh downshift. This rapid drop from the tranny hanging on to 3rd too long before changing to 1st has been covered by others here. Until Toyota owns up to the issue we’re all kinda on our own. Another reason I wish I’d bought a manual.
  19. Dec 23, 2017 at 7:16 PM
    #39
    backcountryj
    Jonathan
    GA
    To be honest I’m actually not hating it.
    Turns out from the drivers seat you can’t see the less than desirable exterior. It’s got decent pep and driving manners. My wife and I both are enjoying the extra interior room for our daughter and dogs. Don’t tell Toyota I’ve been carrying my dogs in their rental, it’s against the agreement :anonymous:
  20. Dec 23, 2017 at 8:40 PM
    #40
    Nick13
    Dominic
    2017 sr
    Just tell them you have a prior agreement with the dog that seems their agreement bill and void
