Carrier Bearing Maintenance?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DGXR, Apr 1, 2010.
  1. Apr 1, 2010 at 4:26 PM
    DGXR
    DGXR [OP] Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    aFe Pro Dry air filter, magnetic oil drain plug, synthetic seat covers, steering wheel cover
    I searched and searched and did not find the info I'm seeking. Did not see any maint info in the manual about the carrier bearing either. Is it sealed & lubed for life? Anything I can do while underneath greasing the U-joint zerks? It's a 2006 4cyl 2wd automatic access cab. Thx
  2. Apr 1, 2010 at 4:35 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    The carrier bearing doesn't need to be serviced. I replaced the one on my 91 toy about a year ago. The bearing was good, but the rubber bushing fell apart. Rancho foreign auto in Moreno valley had one for my truck. Think there is one in compton too.
  3. Apr 2, 2010 at 7:17 AM
    DGXR
    Friend
    Sacramento, CA
    Thanks DD59... since I plan to keep this truck forever, what is involved in replacing the carrier bearing? Can a competent shadetree mechanic do it?
  4. Apr 2, 2010 at 7:01 PM
    desertdude59
    You can do it. On mine I just disconnected one side of the drive shaft(diff side). I pulled the one side out since its a 2 piece drive shaft. Unbolted the 2 bolts on the carrier bearing. Then just re-installed. Easy as that. Sometimes you have to pull the whole driveshaft if it doesnt want to come apart. Its really not that hard to do.
  5. Apr 2, 2010 at 9:22 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    your truck may last forever but the bearing won't. replaced mine at 22,000. Stock bearings suck ass
  6. Apr 2, 2010 at 9:36 PM
    Series1000
    Series1000 Gots a Taco!
    Vancouver Canada
    2007 Access Cab 4X4 4.0L
    3" Redi-lift (spacer lift) up front
    Maybe its just me but I thought that was called a steady bearing, And I though a carrier bearing was part of the diff.
  7. Apr 2, 2010 at 9:42 PM
    bajamoon
    STEVE
    Whittier
    nope, the carrier bearing is the bearing in the middle of the driveshaft
  8. Apr 3, 2010 at 1:05 AM
    reg boulette
    reg boulette Well-Known Member
    Have not had the opportunity to check yet (09 AC) but on previous trucks there is a sliding spline gear where the drive shaft joins the transfer case. While you've got the drive shaft apart for the carrier bearing (also heard it called the steady bearing) put a whack of grease on the spline gear so the shaft goes back and forth easily when shaft speeds up or slows down.
  9. Apr 13, 2011 at 3:12 PM
    07TaCo07
    07TaCo07 Well-Known Member
    oregon
    07 double cab 6" lift
    6" fab tech lift, 35" toyo m/t, 17" teflon wheels
    How much is the carrier bearing and how do u know if its going bad
