Carrier bearing nut
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bizzle, Oct 16, 2024.
  1. Oct 16, 2024 at 5:07 PM
    Bizzle
    Bizzle [OP] Member
    Taylor
    2006 Tacoma rwd access cab
    6” rough country lift kit
    I recently changed out my carrier bearing and doing so, I stripped the nut that one of the bolts to hold the carrier bearing to the frame. Sad part is that the nut is welded onto the metal piece that is also welded onto the frame. I’m debating on going one size up in the bolt threads and seeing if that holds. Or maybe trying to fit a nut up top where the bolt sticks through. Lmk if you guys have any better ideas
  2. Oct 16, 2024 at 6:04 PM
    reallifedog
    reallifedog wat.
    Jordan
    Denver
    08 Tacoma TRD OR
    If it's completely blown through then I'd get a longer bolt with a locknut the same diameter.
    ridefreak likes this.
