Carrier Bearing or Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Davenet20, Oct 28, 2024.
  1. Oct 28, 2024 at 6:15 AM
    Davenet20
    Davenet20 [OP] New Member
    2009 Tacoma 2wd
    I am getting a slight vibration / chatter when accelerating. It only happens between about 22-42 MPH. If I let off the accelerator it stops. I have had one person tell me they think it is the carrier bearing but my mechanic believes it is the transmission and he doesn't work on transmissions. Truck is a 2009 with 155,000 miles. Trying to get some guidance and what to do next. Any help would be appreciated.
  2. Oct 28, 2024 at 7:09 AM
    ThePositiveWay
    ThePositiveWay Well-Known Member
    SE Tennessee
    06' DCLB TRD Sport Super White
    Sony XAV-9000ES Headunit, Steering Wheel Controls, Sony ES Series Door Speakers, Alpine PWE-S8 Sub
    Can you see if putting it in a specific gear forces the vibration or if it is truly dependent on speed? Carrier bearings are relatively cheap, especially at your mileage it might be worth swapping it and seeing.
    Kolter45 likes this.
  3. Oct 28, 2024 at 7:15 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    You can crawl under there and grab the driveshaft and see how much play there is in the carrier bearing rubber. It shouldn't move a lot. At that age and those miles, I would bet the rubber is toast if it is original.
  4. Oct 28, 2024 at 9:55 AM
    TacoTuesday1
    FL
    Go look at it. A stock carrier bearing with 155k is worn. Thats cheaper and easier to deal with.
  5. Oct 28, 2024 at 10:05 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW...
  6. Oct 28, 2024 at 10:13 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    22 mph isn’t fast enough or in the right gear for it to be the “common” torque converter shudder.
    But at 40-45 mph. It could be.
    To test, continue to press the gas. At the same time, touch the brake pedal just slightly. All we need is for the brake lights to come on. If the shudder goes away when you press the brake pedal. I’d lean towards the transmission.
    That said, as of now. Your symptoms sound like a driveline issue. Carrier or u/joint issue.
