carrier bearing play
Discussion in '1st Gen. Tacomas (1995-2004)' started by rab89, Jan 19, 2010.
  1. Jan 19, 2010 at 1:14 PM
    rab89
    rab89 [OP] Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    I was just greasing up my driveshaft, and noticed there is a noticeable amount of play in the carrier bearing.
    I have also been having a whine/ringing noise when i am off the gas and there is back pressure, a bit of a growl at certain rpm's when on the gas, and the whining/ringing is still there, but much quieter when rolling in neutral.
  2. Jan 19, 2010 at 4:03 PM
    4421.frank
    4421.frank Well-Known Member
    Southside chicago
    02 double cab prerunner supercharged
    nasty dent on driver's side bed panel, shabby seats, cigarette burned interior roof, missing berf bar pad, cracked rain visor, removed hood scoop, unmentionable stain on back bench?
    been havinga similar problem with my drive shaft as well. When it was up on the rack I rolled the wheels and noticed it was coming from the u-joint. Although my truck's drive shaft has grease fittings. Which is odd because i thought all toyota drive shafts would have factory closed fittings. Now that I know this I will grease the shaft( :)) lol, evry three months or oil change. I am Wondering what replacing this drive shaft is like though as far as labor involved as well as cost of replacement parts.
  3. Jan 19, 2010 at 4:25 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    there is suppose to be a little play in the carrier bearing but by a little i mean like 1/4'' max. Its not to labor extensive to take out the stock driveshaft, 4 bolts in front,2 in middle holding up the double cardan u joints,4 in back. If you do decide to take it down just remember to set your e brake. The u joints are just like any other u joints to change,quite easy. Dont even bother wastin your time with the 2 u joints in the middle, theyre not meant to be changed,u cant even buy u joints for that part of the shaft. I found out the hard way.
  4. Jan 19, 2010 at 4:27 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    I ended up goin with a 1 piece driveshaft,with some brute force ujoints.it was around 600$ i think
  5. Jan 19, 2010 at 7:06 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    ok so I was just outside trying to find where my noises are coming from, i put the rear end of the truck up on jackstands and had my buddy run the truck in 2nd gear, the grinding noise is MUCH louder than I thought, and is definitely metal on metal grinding, i tried with it locked and it's the same..
    wtf did i break?
  6. Jan 19, 2010 at 7:13 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    any fluid in the rear?
    giggity
  7. Jan 19, 2010 at 7:14 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    ^ good place to start haha. is there anything sticking out that would be stratching or whatever else into the ds by any chance? i know a piece of my gas tanks "skid" was rubbing up against my shaft :D
  8. Jan 19, 2010 at 7:20 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    full of synthetic.
    no, it's most definitely INSIDE the diff, I was told I need to pull the 3rd member, bring it to a gear shop and have them put a new master install kit which is new bearings throughout, and hopefully the R&P is fine, but it's been a month, so I'd imagine it's fucked and I'll need new gears too.
  9. Jan 20, 2010 at 4:05 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    fuck.. that sucks man,keep us posted
  10. Jan 20, 2010 at 5:07 PM
    4421.frank
    Southside chicago
    so how do I find out if my drive shaft is "totally fucked" as well? To whom would I take it to find out? What could I expect to pay for such diagnostic activity?
  11. Jan 20, 2010 at 5:11 PM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    im having simaliar problems with mine . my shaft pings knocks and squecks
  12. Jan 21, 2010 at 5:21 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    how does the shaft get fucked?, u joints make all kinds of noises when they start to shit the bed
  13. Jan 21, 2010 at 5:29 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Hell, I don't see why you couldn't set your drive shaft on a level surface & throw a good level or a straight edge on it(in several places on the driveshaft) for a quick check to see if its bent , warped or ?? Try it & let us know, good luck......:cool:
    ( Hey 300 post, I just rolled a perfect game !!!)
  14. Jan 21, 2010 at 5:31 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Sometimes the only thing that has saved my frame from damage is hitting the driveshaft first (j/k) You see where I'm going with this don't ya ?? lol
  15. Jan 24, 2010 at 3:55 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    lol oh that would suck
  16. Jan 24, 2010 at 6:56 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I was tired of having vibes and noises coming from my drive shaft after lifting, and just bit the bullet on a Tom Woods one piece. What a great mod! Its sooo smooth and strong. :)
  17. Jan 24, 2010 at 7:07 PM
    TRDsport2010
    TRDsport2010 Grease Monkey
    Corey
    Houston, Texas
    2010 Silver TRD Sport
    Better check those u joints before it gets this bad and you damage your yoke too.
    (not my truck, It was a customers 07 prerunner. It was vibrating the truck to death)
  18. Jan 24, 2010 at 7:08 PM
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    ive replaced my carrier bearing and it stoped makeing noise but vibrates at about 40 45 mph??? whats wrong?
  19. Jan 24, 2010 at 7:18 PM
    TRDsport2010
    Corey
    Houston, Texas
    Could be a few things. Tire balance, Was the carrier bearing pressed on straight. are your tires wearing smooth.
  20. Jan 24, 2010 at 8:06 PM
    tacomaforlife
    Robbie
    AIKEN, SC
    yea the tires are fine and the bearing went on just as it came off im assuming the u-joints are bad i hear a noise that sounds like metal raping around the drive shaft ever now and then.
