Carrier Bearing Play
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jones'R, Jan 26, 2010.
  1. Jan 26, 2010 at 9:06 AM
    Jones'R
    Jones'R [OP] My
    Niagara Falls
    08' SR5
    3" Lift
    How much play are these bearings allowed approx. Upon installing my diff drop kit, i noticed that it is able to 'slop' around quite a bit. I didnt measure how much but wondered what the allowable tolerance would be if any at all.
  2. Jan 26, 2010 at 9:10 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    I don't know the anser gut when I was messing around with a carrier bearing shim install I was amazed how much it flexed around in the mount.
    I am sure it is in correct as it was the same before and after I shimmed it.
    Pretty sure that is where the very slight vibration comes from on take off.
  3. Jan 26, 2010 at 7:37 PM
    Wanderer32
    Wanderer32 Member
    Homeless
    09 Tacoma 4x4
    Camburg front suspension lift, OME rear lift
    I also noticed today that there is a lot of play in my carrier bearing. Maybe a total of 1/2 inch. I too have a vibration during take off that lasts for a second or too. I swapped out my carrier bearing shims for rear axle shims to try to fix the vibration but it is still there.
