Carrier bearing question.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kidthatsirish, Mar 22, 2023.
  1. Apr 9, 2023 at 12:10 AM
    Pacificclam
    Pacificclam Well-Known Member
    Carl
    Hawaii
    2010 Tacoma 4x4 Access cab
    6” pro comp lift Kings Coils and Shocks 700lbs Element UCA Atlas Leaf spring kit 17x9 stealth custom series ray 10s -38 33x12.5 toyo open country mt Tom woods driveshaft CSF high performance radiator 4.88 GEARS
    I just felt like when I pushed the gas it didn’t put the power straight to my rear wheels with the 2 piece drive shaft. And sometimes when I really needed to accelerate it felt like I could snap the driveshaft. With the Tom woods it seems like the power is transferred much quicker. Imo
  2. Apr 9, 2023 at 6:29 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    When you go to replace it, put some washers on the bolts between the carrier and mount. This will lower it and take some of the angle off of the rear u-joint.
  3. Apr 9, 2023 at 8:39 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    My truck runs butter smooth with the stock driveshaft and 35s.
    I would assume the CB actually protects the shaft from rock impacts offtoad too. I've witnessed shafts get destroyed from rock ledges.
  4. Apr 9, 2023 at 1:28 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    The two piece driveshaft increases breakover angles slightly by keeping the driveshaft higher under the center of the truck for a longer distance before it angles down to the rear diff.
    Very strictly speaking, a one piece driveshaft will be more efficient because technically the CB and the intermediate U-joints on the two piece have some amount of flex/play/slop/friction, but I would be shocked if it was anything that could be detected even by a really good modern dyno.
    Some people report positive seat-of-the-pants results from a one piece shaft just as they do with various other modifications, and I'm happy to let people be happy with the way their truck feels to them without belaboring the point above.
    If you don't offroad, a one piece will, as mentioned in this thread, remove some points of mechanical failure aka future maintenance (carrier bearing, intermediate U-joint), and you could probably sell your stock DS to offset some fraction of the cost.
    FishaRnekEd and hoffengineering like this.
  5. Apr 9, 2023 at 11:10 PM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    This is exactly my take on reports on it feeling "more responsive" or "more powerful". It's purely a "butt-dyno" feeling, not a real improvement in performance.
    If it gets rid of vibe, that's a plus for sure, but I doubt there is any real change in performance. I assume that a single piece driveshaft has a slightly lower moment of intertia compared to the stock driveshaft but that it has a negligible effect on performance, especially considering the amount of rotational mass in the rest of the drivetrain as a whole.
    That being said, of the people I know personally that have swapped over to single piece driveshafts (including myself, on a different vehicle), none of them have regretted the purchase. At the end of the day, it's your truck, do what you want, just don't expect any tangible change in performance.
    Pacificclam likes this.
  6. Apr 12, 2023 at 4:43 PM
    kidthatsirish
    kidthatsirish [OP] Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Well... I already bought the Spicer. I'm not to worried about trying to gain performance on this pickup. If I truly want to do that I'll get a supercharger kit and exhaust.
