Carrier bearing question
Discussion in 'General Tacoma Talk' started by shoulderpads, Dec 16, 2023.
  1. Dec 16, 2023 at 8:44 AM
    shoulderpads
    shoulderpads [OP] Active Member
    Zac
    2003 Tacoma TRD Off-Road
    Hello all. I’m stumped. My driveshaft carrier bearing went out so I got A new one and put it on. The new part had almost more play in it than the old. So naturally, I picked up another one. Same thing. What would cause this? 2 bad parts in a row?
  2. Dec 16, 2023 at 9:49 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    I am pretty sure the carrier bearing has play/movement from the get go. you can jiggle it for sure.
    what kinda movement are you talking about.?
  3. Dec 16, 2023 at 9:57 AM
    Bishop84
    Bishop84 Well-Known Member
    We've found all but OEM have lots of play, even good 3rd party name brands.
  4. Dec 16, 2023 at 7:02 PM
    shoulderpads
    Zac
    I’m talking an inch or more of play. Returned the *2nd* Auto Zone part for a NAPA part.
  5. Dec 17, 2023 at 7:08 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    some of it has more to do with being aftermarket and/or remanufactured parts. some don't tolerance them right, some, i guess mis-read the tolerance required.
    i understand going with aftermarket, but the crapshoot is really just to keep trying different brands to find one that toleranced it correctly. oem likely does as well, for at leas 2x's the cost...
  6. Dec 17, 2023 at 7:14 AM
    aficianado
    back to bone stock.
    I mistakenly changed out a carrier bearing once. I yanked on it and it jiggled. turned out that is kinda the deal.
    I had one really go out recently and it made a racket. on the garage floor it looked cooked.
  7. Dec 17, 2023 at 7:18 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    The bearing is mounted in rubber for a reason. Yes it will have some movement up and down and side ways that is normal.
  8. Dec 17, 2023 at 7:49 AM
    aficianado
    back to bone stock.
  9. Dec 17, 2023 at 7:55 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
