carrier bearing replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SecondThoughts2001, Nov 14, 2024.
  1. Nov 14, 2024 at 10:11 AM
    SecondThoughts2001
    SecondThoughts2001 [OP] Member
    Hello folks,
    My mechanic told be there's a lot of play in the carrier bearing on my 2012 taco, which has 230K miles. Has anyone had this replaced before? He doesn't work on many Toyotas and seemed to be over over the place on the cost. Any thoughts on how hard of a job this is and what it should cost approximately? Thanks!
  2. Nov 14, 2024 at 1:38 PM
    Marc70
    Marc70 Well-Known Member
    Marc70
    Northern Ontario
    2012 TRD Sport 4.0L, 6MT
    2” lift, ARB front bumper, steel rear bumper, Trail Gear weld-on sliders, aFe cai, 2lo kit, air bag suspension, RA Motorsports AL skid plates
    Not that hard to do. YouTube is your friend.
    I’ve had some slop in mine (cheap block lift) but no worries.
    As long as it spins you’re probably good.
    I’m sure others will chime in with their opinions, ideas.
  3. Nov 14, 2024 at 2:14 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    4 bolts on the front of the shaft.
    4 bolt on the rear.
    2 in the carrier.
    The center U-joint has to come out. (to get to the big nut)
    Then a great big nut holding the carrier on.
    Getting the old carrier off will be the biggest job.
    And possibly the u-joint out if the caps are rusted.
    Naveronski, kidthatsirish and Marc70 like this.
  4. Nov 14, 2024 at 2:38 PM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    not wrong! replace the U joints and the carrier bearing all at the same time! pretty decent
    only tip get a good quality paint marker and a long straight edge mark between the yolks a long line on both flanges to help line things all lined up! and I marked my flanges as well with the paint marker to make sure that I kept things from moving around to much! hoping to lessen all the possible vibration.
    and use some anti seize in the splines of the shaft when you put the yolk back down and tighten up the center nut.
    Naveronski and Steves104x4 like this.
  5. Nov 14, 2024 at 2:48 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Just put in a 1pc driveshaft and be done w/ it all together.
    TnShooter likes this.
  6. Nov 15, 2024 at 3:08 PM
    iiggii
    iiggii Well-Known Member
    jeff
    2010 tacoma access
    lift n radio
    where did u get the 1 pc shaft ?
  7. Nov 15, 2024 at 3:27 PM
    TnShooter
    Deogee
    STOCK
    It’s under Powertrain / Chasis
    The scroll down to read brake line and tube.
  8. Nov 15, 2024 at 6:50 PM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    got mine from Tom Woods. Not sure if they’re still making them or not though.
  9. Nov 15, 2024 at 7:18 PM
    BadAndy10
    BadAndy10 Well-Known Member
    the 541
    '10 DC TRD OR
    Fox 2.5" extended travel coilovers, SPC UCA's, Wheeler's AAL & 5100's, Relentless front plate bumper, SCS F5's w/285's, Superbumps
    They've discontinued them, but do have a link to another company making a 1 piece aluminum shaft.
    Chris(NJ)[QUOTED] likes this.
  10. Nov 16, 2024 at 4:21 AM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Nothing wrong w/ aluminum. Even better if lighter than the steel ones for that decrease in rotational driveline mass. What company?
  11. Nov 16, 2024 at 7:22 AM
    coylifut
    coylifut Well-Known Member
    tk
    portland or
    2011 TRD Sport DBC LB
    Weather Techs, Wet Okoles, cbi rear bumper with swingout
    I pulled mine a couple of months ago and sent it to a local driveline shop. All new u-joints, carrier bearing, carrier bearing mount, slip yoke lube, painted and spin balanced for $275. All the replacement parts were Spicer. You can do it yourself, you can have your mechanic do it, but neither of you will do it as good as a driveline shop. If you send it out, you'll end up with a spin balanced driveline, all new parts and painted flat black.
    I have a friend who worked as Toyota dealer tech for a decade. The manager who ran the shop in his last few years deemed all driveline repair unprofitable and mandated that all driveline work be sent out to the service. The work was time consuming. And too often, the rig ended up being brought back to the shop with customer complaints of vibes.
    kwanjangnihm, Marc70 and steelcity2 like this.
  12. Nov 16, 2024 at 12:33 PM
    BadAndy10
    the 541
    '10 DC TRD OR
    Naveronski and Chris(NJ)[QUOTED] like this.
  13. Nov 17, 2024 at 1:13 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Agreed, I found a block of wood and a 3 or 5 pound hammer help immensely!
    TnShooter[QUOTED] likes this.
  14. Nov 18, 2024 at 7:17 PM
    kurts74
    kurts74 Well-Known Member
    Flagstaff, Arizona
    2nd Gen 4-door longbed
    ICON Mid travel set up with Hard candy shell
    How long should a carrier bearing last? I replaced mine in 2020 and just starting getting that god-awful squeak again. I do a good amount of offroading, but <5 years still seems too short.
  15. Nov 18, 2024 at 7:25 PM
    TnShooter
    Deogee
    STOCK
    Depends.
    5 years is a long time for some aftermarket parts "Doorman".
