carrier bearing solution?
Discussion in 'Long Travel Suspension' started by joey34mx, Oct 17, 2010.
  1. Oct 17, 2010 at 3:01 PM
    joey34mx
    joey34mx [OP] Well-Known Member
    Joey
    Southern California
    2005 Tacoma V6 prerunner
    ok guys, i have a 05 tacoma extra cab VVVVVVVV and i go through a carrier bearing every month. :confused:
    its super frustrating to hear the squeak when im driving it down the road. i have the deaver j66 bolt on leaf pack.(1 1/2 in. lift)...... all i have done to my driveshaft now is a 3/4 inch spacer.
    i understand that the lift give the driveshaft the wrong angle which shreds the bearing but my question is...
    is theyre any solution that will make my carrier bearing last more than a drive down the block? :eek:
    ive heard of getting a one piece driveshaft or having DMZ fab build a carrier bearing with a shortened driveshaft....but what really works??:confused:
    any help would be great
  2. Oct 17, 2010 at 3:06 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Custom driveshaft could be built for your new angle.
    Axle shims may also help you out, if that hasn't been tried. You may also try a carrier bearing drop.
  3. Oct 17, 2010 at 3:09 PM
    joey34mx
    Joey
    Southern California
    thanks. do you know where i can buy these carrier bearing drops? and how big of a drop would be needed for a 1 1/2 in. lift?
  4. Oct 17, 2010 at 3:13 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
  5. Oct 17, 2010 at 3:17 PM
    jandrews
    Drops are a bit of a feeling out process. Not only does a lift alter the height of the driveshaft, it also alters the angle at which the driveshaft passes through the carrier bearing.
    Usually you can minimize the ill effects of this by getting the shaft back pretty close to stock angles. Even with that, your carrier bearing will still wear a bit faster than normal.
    The only true solution is a custom driveshaft...going to one-piece eliminates the carrier bearing entirely.
    Toytec has shims and carrier bearing drops. Check out their stuff.
  6. Oct 17, 2010 at 3:17 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    hit up beefed taco, he a vendor on here
    http://www.tacomaworld.com/forum/beefed-taco/
    i have a CB drop bracket from him for my 1st gen, it's a great product and does wonders for correcting the drive shaft angle and add strength to the CB
    i am almost 100% sure he's working on a bracket for the 2nd gen
    here's a pic of the bracket for my truck
  7. Oct 17, 2010 at 3:27 PM
    joey34mx
    Joey
    Southern California
    thanks alot matt, this looks like it could work fine. i went ahead and sent a PM to beefed.
  8. Oct 18, 2010 at 7:14 PM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
  9. Oct 21, 2010 at 8:41 AM
    chilidogrc
    chilidogrc Play stupid games, win stupid prizes
    Rodrigo
    San Diego
    2016 4Runner
    OP, a little off topic, but you got any more pics of your front bumper?
  10. Oct 21, 2010 at 8:46 AM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    I have the same leaf pack, and had 2* shims put in. There was a little weird vibe before the shims but it is mostly gone now, and have never needed to replace the carrier bearing.
    I got my shims from Deaver, they are steel not aluminum like most places sell(the alum ones get bent/smashed over time)
    good luck
