Carrier bearing solution
Discussion in 'Technical Chat' started by Wonderboy112, Apr 21, 2024.
  1. Apr 21, 2024 at 9:39 PM
    Wonderboy112
    Wonderboy112 [OP] New Member
    2006 tacoma trd sport
    So I currently have an issue where I’m blowing through carrier bearings and u joints, I know a lot of people go with a one piece drive shaft or the CB drop kits, but I’m thinking has anyone thought of doing a CB spacer that’s more of a larger wedge shape so that theoretically would make your two piece drive shaft be perfectly straight to the rear diff just like a one piece would?
    Any reasons why this won’t work or why i haven’t heard of anyone doing this, I’m tempted to try it myself to see how it would go.
  2. Apr 21, 2024 at 9:46 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  3. Apr 21, 2024 at 9:50 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Welcome to Tacoma World. First thing to do is go through the basics and make sure your angles are good first. Find some time and go down the rabbit hole on this thread first before jumping to inventing a new band-aid fix.
    https://www.tacomaworld.com/threads/drive-shaft-vibrations-solved-step-by-step.244535/
    TnShooter likes this.
  4. Apr 21, 2024 at 10:25 PM
    TacoTuesday1
    FL
    What truck
    want to check my angles to verify they’re good
    But otherwise running a ford poly IEDLS carrier bearing on 2nd gen
    Doesn’t seem to have issues.
    put a plate. Flipped it. Spaced it. Like folks say to do on DCSB fitment
