Carrier Bearing that lasts?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Alderleet, Oct 11, 2013.
  1. Oct 14, 2013 at 6:53 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    X2 perfect examples of everyone in this thread who didnt go OEM the first time
    jammer likes this.
  2. Oct 15, 2013 at 3:59 AM
    VeeSix
    VeeSix Yotahead, Deadhead.
    Tennessee, USA
    2011 Tacoma 4x4
    2018 Tacoma - gone 2003 Tacoma - gone 1983 FJ60 - gone 1988 BJ73 - gone 1992 FJ80 - eternal
    Serious question - other than suspension, is there anything on these trucks that OEM isn't best for?
  3. Oct 15, 2013 at 4:21 AM
    sgrappone
    sgrappone Well-Known Member
    Scott
    Moncks Corner, SC
    04 AC 4X4
    You have to suck it up and pay for OEM. I made the mistake of buying a Dorman.
    jammer likes this.
  4. Oct 15, 2013 at 6:55 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Not so serious answer - I would't buy OEM bumpers
    Black DOG Lila and otis24 like this.
  5. Oct 15, 2013 at 7:19 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I didn't think the OEM one was all that great to begin with so I couldn't justify spending 3x as much for a crappy setup. I'm still looking to find a greasable bearing that is a direct bolt in replacement.
  6. Oct 15, 2013 at 7:26 AM
    BamaToy1997
    Bill
    Navarre, FL
    If your original failed, and a replacement failed in that manner, I would be looking at something CAUSING the carrier to fail. Imbalance in driveshaft, incorrect driveline angle, etc.
    X2
    jammer and cruxofthebisquit like this.
  7. Oct 15, 2013 at 7:53 AM
    sgrappone
    Scott
    Moncks Corner, SC
    04 AC 4X4
    There is this option:
  8. Oct 15, 2013 at 8:12 AM
    sgrappone
    Scott
    Moncks Corner, SC
    04 AC 4X4
    You also have the option of a Tom Woods custom one piece driveshaft. My issues with my CB came from improper driveline angles so I can't say the Dorman was junk but the OEM CB is definitely better quality compared to the Dorman. I ended up installing 2* shims to correct my pinion angle and no longer have any vibe issues. One thing I learned is that all trucks will not handle the same when you start adding lift components. Even with a TW one piece you may have vibes and have to adjust pinion angle. All you can do is try one remedy, if that doesn't work then you may have to try another until you get the results you like. It sucks but that is the price you pay when you add lift components.
    jammer and Hamer95USA like this.
  9. Oct 15, 2013 at 12:07 PM
    Alderleet
    Alderleet [OP] Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    Had.
    I had a 1 piece from tom woods already. The problem with 1 pieces, is the fact they are unstable at high speeds. Tom woods aknowledges that, and they realize toyota had some intelligence when they designed the 2 piece.
    It wobbled like a bastard at highway (75mph) speeds. It was LESS voilent, with the 2 piece OEM and dogshit carrier bearing...
    jammer likes this.
  10. Oct 15, 2013 at 12:27 PM
    Pugga
    Massachusetts
    I saw that thread but it's not a direct bolt in replacement. It drops the location of the carrier quite a bit in the process so if you're not lifted or not lifted very much, that's not a great option unless you want to redo the mounts. A local member redid his cross member so it mounted a greasable bearing like that upside down and kept it in the same spot.
  11. Oct 15, 2013 at 12:35 PM
    Large
    Large Red
    I had mine up to about 85 mph and it felt fine (albeit, it wasn't a TW one piece but it was made by a local drive shaft shop).
  12. Oct 15, 2013 at 2:24 PM
    BamaToy1997
    Bill
    Navarre, FL
    I can't speak for Tow Woods, because I do not know their product, But I have seen trucks with one-piece drive shafts almost 6 foot long running with no vibration at higher than "legal" speeds.
  13. Oct 15, 2013 at 2:26 PM
    Large
    Large Red
    There is a highway with an 85 mph speed limit I've been on here in Tx, but to reiterate what you were saying, the 1 piece got rid of 95% of my vibes when I had it installed.
    Running Board Man likes this.
  14. Oct 15, 2013 at 4:39 PM
    sgrappone
    Scott
    Moncks Corner, SC
    04 AC 4X4
    That confirms my saying that every truck will not respond or handle the same as others with identical components. For example I installed an identical lift as another member on here, he did not have to install axle shims but I did. Other people have had good results with a TW. The key is find what remedies your vibe issues.
  15. Oct 16, 2013 at 8:25 AM
    #35
    jeepdude
    jeepdude Regular Member
    Jesse
    Connecticut
    2004 ext cab 4x4 TRD, bone stock for now
    Greaseable....YES!
  16. Oct 16, 2013 at 8:33 AM
    #36
    Pugga
    Massachusetts
    I know, novel idea, right?
  17. Aug 24, 2020 at 10:02 AM
    #37
    Dylwhit
    Dylwhit Well-Known Member
    Dylan
    2004 2.7l extcab
    resurrecting this thread...
    I have 2x failed dorman carrier bearings since October and was looking for a spicer bearing for my truck (04', 2.7L, 4x4, AT, ext cab) and cant seem to find a good fit. Rockauto doesn't seem to have any decent quality bearings and Im pretty sick of taking my driveshaft apart. Anyone have a cheap alternative to buying the OEM carrier bearing direct form the taco dealership? They want close to 300bucks.
  18. Aug 24, 2020 at 11:02 AM
    #38
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    What can I say my original is around 250,000 .
    I would pay $300.00 for another 20 years you might want to shop some more my price comes in at less then $200.00
    SafetyDang and Running Board Man like this.
