Carrier Bearing - This doesn't look right
Discussion in '1st Gen. Tacomas (1995-2004)' started by mwrohde, Oct 14, 2015.
  1. Oct 14, 2015 at 3:28 PM
    mwrohde
    mwrohde [OP] Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    I seriously doubt there should be this much movement, but before I dig in I'd like more experienced opinions. I shot this while laying under the truck, holding my phone with one hand, and pushing up on the drive shaft with the other. Let me know what you think.
    Thanks,
    https://youtu.be/U4mw9ReyRzE
  2. Oct 14, 2015 at 3:29 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    Looks like to much play to me.
  3. Oct 14, 2015 at 6:19 PM
    Aught2TaCO
    Aught2TaCO Well-Known Member
    Troy
    Wheat Ridge, CO
    '02 Taco TRD, aka Pearly
    Billie 5100's, new leafs, Falken WILDPEAK A/T 3W, 265/75/16E
    Yours is in bad shape for looking so new. Here's one with much more mileage that looks a little better than yours.
  4. Oct 14, 2015 at 6:44 PM
    mwrohde
    Sugar Hill, GA
    ok, so bad. What's the risk in driving it?
    I don't know when mine was replaced. Before I bought the truck a couple of years ago.
  5. Oct 14, 2015 at 6:56 PM
    Aught2TaCO
    Troy
    Wheat Ridge, CO
    You could hurt your transmission and/or rear differential if it breaks loose. Do you have axle wrap as well?
  6. Oct 14, 2015 at 6:58 PM
    mwrohde
    Sugar Hill, GA
    I don't even know how to tell.
  7. Oct 14, 2015 at 7:13 PM
    Aught2TaCO
    Troy
    Wheat Ridge, CO
    Does the truck "thump", or a feeling of a little push from behind, right before coming to a complete stop? Will a thump happen when starting to accelerate? There's some good threads on the subject here. I'm not saying that is what caused the problem, but it could've helped. Replace the carrier bearing first, then go from there.
  8. Oct 14, 2015 at 8:08 PM
    mwrohde
    Sugar Hill, GA
    I don't feel a thump when stopping. I do get some hopping when starting, but I've always attributed that to bad clutch work.
    If it's ok to drive, I'm going to take it Friday from Atlanta to Hilton Head. Back Sunday. Looks like about 600 miles round trip.
    Thoughts on that?
  9. Oct 14, 2015 at 8:20 PM
    Aught2TaCO
    Troy
    Wheat Ridge, CO
    Can't say Matt, it could be tomorrow or a thousand miles down the road. 600 miles is only going to worsen the bearing, it won't get better.
  10. Oct 14, 2015 at 8:26 PM
    Phoenix autoworks
    Phoenix autoworks Stock but fun!!!
    Josh
    North Phoenix
    95.5 Tacoma 4x4 3.4 manual
    Stock but I use it anyway!!!
    Don't do it. It's already that loose now, image adding passengers, cargo and 2 weeks of driving in just a few days.. Not a good idea considering it's a much cheaper fix at home then on the side of the road far away from tools and auto parts stores. Pay for the bearing, not the bearing and a tow truck bill...
  11. Oct 14, 2015 at 8:56 PM
    Aught2TaCO
    Troy
    Wheat Ridge, CO
    Listen to the man Matt.
  12. Oct 15, 2015 at 1:29 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    About the worse that could happen is the bearing fail completely .
    then you have two pieces of the drive shaft wailing around does one take out the fuel tank good enough to cause a leak
    Sparks from parts dragging on the road enough to ignite vapors ???
    Rear section catches in a expansion joint throwing the truck to the right or left.
    Of course the rear drive shaft in destroyed did it also take the flanges on the differential and transfer case as well.
    Now it is pretty cheap to fix before things go really bad!!
  13. Oct 15, 2015 at 3:37 AM
    mwrohde
    Sugar Hill, GA
    Alright. Thanks, guys. I'll look into a rental car for the trip.
    On to cause. Is this a normal wear and tear item, or is something stressing it causing it to fail prematurely? On the other hand, maybe it's not premature - I don't really know when it was last replaced. Or, maybe it was replaced with a cheap part.
  14. Oct 15, 2015 at 4:35 AM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    Normal wear and tare. You could fix it in an hour or 2 if you want. Just take off that half of the axle (not the flanges, let a machinist do that) to a machine shop with a new support bearing and they'll swap it for you.
  15. Oct 15, 2015 at 5:12 AM
    deckeda
    deckeda Well-Known Member
    '04 Double Cab PreRunner SR5
    Yes to both. Axle wrap is a natural occurrence with leaf spring suspensions. Older/weaker springs permit more axle wrap. This creates additional vertical and horizontal (as viewed from the side ...) movement of the driveshaft. And that extra movement is something the bearing must deal with. I would suspect there's no way axle wrap can't wear out the bearing somewhat quicker.
    And you've seen this? https://www.tacomaworld.com/threads/how-to-replacing-carrier-bearing.260283/
  16. Oct 15, 2015 at 5:33 AM
    mwrohde
    Sugar Hill, GA
    Thanks. And, yes, I've seen it. I'm committing it to memory now.
  17. Oct 15, 2015 at 7:06 AM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    All it takes is a socket and breaker bar to get the flange off. No need for a machine shop at all. Pop the flange and bearing off, stick the new bearing on and then the flange. Done.
    Seriously? Quit fear mongering. The bearing itself is probably fine if he can't hear it squealing. The rubber around the bearing has deteriorated enough that the bearing moves in the pocket. Even if the bearing did sieze.. It's a captured unit that would be held together by the cage around the rubber. It's not going to sound good but it's not going to make his truck blow up in a ball of fire like you seem to think :confused: :rolleyes:
  18. Oct 15, 2015 at 8:00 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    ^what he said. the bearing isn't the piece that joins the driveshaft. it allows it to "float" to absorb vibrations. it would have to shear off the 4 bolts connecting it on either end. worst that will happen is it sounds like shit and people look at you funny. :oops:
  19. Oct 15, 2015 at 10:48 AM
    mwrohde
    Sugar Hill, GA
    Don't you be looking at me funny!
  20. Oct 15, 2015 at 11:41 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    If it were I, and I drove on the suspect bearing. about 50 miles down the road I would begin worrying about what that "noise" is. What if it comes apart... I shoulda fixed it... And then the rest of the trip would be a nightmare...
