Carrier bearing vibration
Discussion in '1st Gen. Tacomas (1995-2004)' started by newertoy, Sep 17, 2011.
  1. Sep 17, 2011 at 9:39 AM
    newertoy
    newertoy [OP] Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Thought I would post this again--
    Was getting vibration at various speeds( could feel it under foot)
    35-40. 30-35, 40-45 Did not seem to have a specific MPH.
    Got worse when weather cooled. CARRIER BEARING was BAD. Rubber had cracks and worn in places. Replaced bearing--still had vibration but, not as bad. While replacing bearing--I greased all u-joints--I THOUGHT--
    I MISSED the one the lubes the spider bearing--it is difficult to see.
    while drive shaft is removed --look closely--(check ALL MOVEMENT of joints,) you will FIND the FITTING.
    now is SMOOTH AS SILK.
  2. Sep 17, 2011 at 3:30 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    Purchased the bearing @ "driveshaft parts"
    38-+ 13 shipping== $51--less than half the other peoples prices.
    Appears to be EXACT replacement. Appearance is identical to what was OEM.
    IDENTICAL----HMMM--checked other sites--bet that is where they get the part--buy direct "driveshaft parts"
  3. Sep 17, 2011 at 3:32 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    what exactly are you calling the spider bearing?
  4. Sep 17, 2011 at 3:36 PM
    MotoXdoer
    MotoXdoer taco?
    Nate
    San Luis Obispo, Ca
    06 Prerunner 4.0 a/c beast
    k&n cai 63 series intake, blacked out headlights, blacked out tailights, magnaflow pro offroad 17115 dumped, URD competetion y-pipe, total chaos 3.5" long travel, fox 2.5x8" remote resevoir shocks, allied 4" spindles, toytec 2" AAL, 20% tint up front and 5% rear, satoshi grille, ddm 50w 6000k hid's. wet okole custom trd seat covers with heaters. 4:56 nitro gears with arb rd129 air locker, arb ckmta12 dual air compressor.
    Check Ur u joints not the bearing. I thought my bearing was bad it was shattered u joints
  5. Sep 17, 2011 at 3:38 PM
    2000GTacoma
    Snow Hill NC
    what are the spider bearings though? are we talking about inside the diff?
  6. Sep 17, 2011 at 4:38 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
  7. Sep 17, 2011 at 5:30 PM
    2000GTacoma
    Snow Hill NC
    ok gotcha i always heard that as a cv joint there. but i do know what you are talking about. did the 4x4s come from the factory with grease zerks? its dark here so hard to go check
  8. Sep 18, 2011 at 8:33 AM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    Yes. mine had a fitting
  9. Sep 18, 2011 at 1:54 PM
    2000GTacoma
    Snow Hill NC
    on mine i just have 2 zerks one in each u joint is there another that actually goes inside ? i looked all around the area there and could not see another zerk
  10. Sep 18, 2011 at 2:26 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    I did not see the fitting until the shaft was removed!!
    It is in the MIDDLE--
    If you are not looking for it -you will not see it--BETWEEN U-joints.
    You might need to turn the shaft--all my fittings are on the same side.
    Put your finger between the joints--you can feel it.
    Most likely covered with grease. IN THE CENTER.
    Just went to look at mine--TIGHT SQUEEZE--
    U joint X U joint
    fitting-fitting-fitting
    Keep me posted--let me know if you find it.
  11. Sep 18, 2011 at 2:31 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    x2...had to have all 3 replaced...along with the carrier bearing lol
  12. Sep 18, 2011 at 2:44 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
  13. Sep 18, 2011 at 3:59 PM
    2000GTacoma
    Snow Hill NC
    you sir are right 3 zerks right there 1 per u joint and 1 in the middle it took me a couple mins to find once i found it it was no problem to grease. thank you sir
  14. Sep 18, 2011 at 5:05 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    Let me know if it solves your vibration problem--.
    It was driving me crazy--though I had greased them all--I just misseg the IMPORTANT one.
    I wonder how many others are having the same trouble?
    That fitting is easy to miss--and i believe causes the carrier bearing to wear out and/or malfunction.
    I am not on tc forums all the time(like some)--If YOU see someone having the same difficulty--PLEASE pass it on..
  15. Sep 18, 2011 at 5:13 PM
    2000GTacoma
    Snow Hill NC
    will find out tomorrow on the way to school i think a lot of my problem is the tires not wearing even at all. im going to true the on a tire truing maching buddy has got one
  16. Sep 19, 2011 at 12:06 PM
    02ttaco
    02ttaco Member
    Tyler
    Maryland
    02 tacoma trd
    three inch spacer lift with blocks in the rear
    I have a 2002 tacoma and noticed a vibration in driver side floor at random speeds. Seems to me i have no play in the u joints but the driveshaft has about 3/4" of play up and down at the location of the CB. The truck has also been shifting hard (auto) from first to second gear when under a load. Hoping that the carrier bearing is the issue not the transmission. Would be very GRATEFUL for thoughts
  17. Sep 19, 2011 at 2:04 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    If the ujoints have started to vibrate from lack of lube, it's too late to salvage them with lube. They are toast. It would make for a good diagnostic for finding marginal ujoints though.
    My front driveshaft has a zerk on the center of both ujoints, the rear has a zerk on the end cap of both ujoints. Make sure you see grease come out of all four of each of the joint's seals, or it's not properly greased.
  18. Sep 19, 2011 at 3:09 PM
    2000GTacoma
    Snow Hill NC
    made a huge difference u joints are fine it was that bearing in the middle causing problems vibrations almost dissappeared. put more grease in this afternoon and i still had popping and all coming from the joint hoping its not ruined and will be ok now
