carrier bearing
Discussion in 'Technical Chat' started by Detective_Dan, Mar 8, 2011.
  1. Mar 8, 2011 at 3:44 PM
    Detective_Dan
    Detective_Dan [OP] "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    slightly before i lifted my truck with 5100's, i noticed a SLIGHT vibe coming from the rear of my truck. i figured it was an unbalanced tire and kinda put it out of sight, out of mind. then i lifted it, put on new wheels and tires and it now seems worse. it only happens from about 53-58MPH
    i can see my tires in my side mirrors and they are NOT out of balance, straight as an arrow.
    i checked my carrier bearing but i am not really sure what it would look like if it is bad. it is not loose at all, and the rubber (or whatever it is) inside the bearing seems ok.
    how do i tell if my carrier bearing is bad, and do you think that this is even the cause of the problem?
  2. Mar 8, 2011 at 5:42 PM
    Detective_Dan
    Colorado Springs
    bump. need some help here
  3. Mar 8, 2011 at 5:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Carrier bearing vibes start around 35 up to about 50 mph. Did you have yuour tires road force ballanced? You dont always see the tire moving if its out of ballance.
  4. Mar 8, 2011 at 5:46 PM
    Detective_Dan
    Colorado Springs
    no, they were machined balanced. but it did the exact same thing before and after the lift. before the lift i was on stock sport 17's and dunlops, after 5100's im on pro comp 8069's and 285/75/16 hankook atm's
  5. Mar 8, 2011 at 5:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Have them road force ballanced.
  6. Mar 8, 2011 at 5:48 PM
    Detective_Dan
    Colorado Springs
    ok, if i do that and if it still vibes the same, would you say it is the carrier bearing? it feels like the vibe is rear passenger side. i checked all suspension and everything is nice and tight, not close to coming loose
  7. Mar 8, 2011 at 5:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont think you'll have vibes after that, but its best to start with the tires then go from there.
  8. Mar 8, 2011 at 6:03 PM
    Detective_Dan
    Colorado Springs
    alright thanks chris
