carrier bearing
Discussion in '1st Gen. Tacomas (1995-2004)' started by beechairplanes, Mar 6, 2009.
  1. Mar 6, 2009 at 7:07 PM
    beechairplanes
    beechairplanes [OP] Terrain
    Arizona
    01 tacoma 4x4 trd
    lift, yokahama geolanders,
    I am new to the forum and also new to toyota's. I have recently purchased a 2001 tacoma 4dr 4x4 w/ 120,000 miles. after driving the truck home 250 miles from the seller I realized that the driveshaft carrier bearing had disintegrated. Is this an easy fix? I already own the part. m also taking the truck in tomorrow for a full tranny flush and filter. What do you guys think?
  2. Mar 6, 2009 at 7:09 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    carrier berrings arent hard to do..Get a chiltons manual.
    Id advise against doing the tranny flush unless its been done before. Some say that if it hasent been done, it could cause some major slipping.
  3. Mar 6, 2009 at 7:13 PM
    beechairplanes
    Arizona
    01 tacoma 4x4 trd
    I dont understand that. Why would it create slippage if the system gets flushed and the filter gets changed? Wouldnt it be worse to leave old fluid in the tranny? Do you know what toyota recommends?
  4. Mar 6, 2009 at 7:16 PM
    hillbillytaco
    hillbillytaco HOT!!
    Jeremy
    westbyGodvirginia
    06 impulse red trd off road dc v6 6spd
    i hear that all the time too about flushing the tranny a buddy of mine had it done to his f-150 and the tranny went to shit i know its apples to oranges but thats my 2 cents
  5. Mar 6, 2009 at 7:21 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    they say new fluid "shocks" the internals. You can take it to toyota and see what they say. IF they say it will be ok, and it slips, then its on them
  6. Mar 6, 2009 at 7:32 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    a transmission flush with that many miles can be bad....really bad. it can cause all kinds of leaks and major slipping too, since the transmission is used to the fluid thats in there. that being said..................if it has been flushed in the past 50 or 60k miles, you may be ok for the flush......otherwise, drain and fill the transmission,and if you want...drop the pan and change or clean the filter. you can do a drain and fill 3 or 4 times and you'll have about 90% new fluid in there.
    for the carrier bearing, not too bad to change..................hardest part is breaking the drive shaft bolts loose.
