Carrier Bearing
Discussion in 'New Members' started by brooks3307, Mar 6, 2021.
  1. Mar 6, 2021 at 9:56 PM
    brooks3307
    brooks3307 [OP] New Member
    So I have a 2018 tacoma with a 3 in leveling kit. I have really bad vibration all over truck. I was told the carrier bearing needed to be replaced due to have excessive play in it. I was told that my tires were worn uneven and I needed to replace which I could tell that needed to be replaced. I was told that if you replace carrier bearing, you must re-balance drive shaft. Is that correct? I have also been told that was not the case and I should be fine just replacing the carrier bearing. Any information would be helpful.
    Black DOG Lila likes this.
  2. Mar 7, 2021 at 3:34 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    Driveshaft should be marked before disassembly and reassembled correctly. Correct orientation of Ujoints and splines is important. That said,you should be ok unless you lost the welded on balance weights.
    buckhuntin-tacoma likes this.
  3. Mar 7, 2021 at 3:58 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    Ur vehicle not very old
    U dont mention mileage...................????
    improper installation of lift kit could be the issue more so than carrier bearing
    no less it depends on if reassembled properly
  4. Mar 7, 2021 at 4:24 AM
    brooks3307
  5. Mar 7, 2021 at 4:25 AM
    brooks3307
    It has 58k miles.
  6. Mar 7, 2021 at 4:43 AM
    ROAD DOG
    FEW
    ANY issues after modifucations invarably point towards that event
    worn tyres will cause as much an issue as the driveshaft / carrier bearing
    bearing installed properly DOES NOT require new shaft
    front to back usually the factory get it right !!!!
    a matter of timing & balance
    * tip :
    before taking uni joints front / rear or disasembling middle carrier
    use white.........red ........blue paint ( does NOT take a lot ! )
    paint all components on each juncture...............along each phase same color
    white at front uni....carrier.....rear SAME PASE !!
    rotate paint red same way.........................
    when reassembly U cant go wrong hooking up wrong ‘ Phase '
  7. Mar 7, 2021 at 5:12 AM
    Black DOG Lila
    Virginia
    X2 what @ROAD DOG said:thumbsup:
    AND
    The difference between 3" lift and "3" leveling kit" is leveling front 3" can cause front alignment issues/tire wear.
    3" lift can cause alignment issues/tire wear plus driveshaft vibration due to increased DS angles.
  8. Mar 7, 2021 at 5:20 AM
    Black DOG Lila
    Virginia
    Lifts are detrimental and don't add Axle clearance.
    Looking COOL ain't worth all the problems lifts create.
    My 2¢
  9. Mar 7, 2021 at 6:51 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  10. Mar 8, 2021 at 5:17 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
