Carrier Drop Bearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05RedTaco, Dec 10, 2011.
  1. Dec 10, 2011 at 10:18 AM
    05RedTaco
    05RedTaco [OP] Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I lifted my Prerunner with 2" spacers up front and will be lifting the rear with Toytec AAL, I got those used so its impossible determine if they will do 2" lift or 1" and 1/2.
    My question is should I get carrier bearing kit, to prevent my carrier bearing going bad or is it not necessary with that small of a lift?
  2. Dec 10, 2011 at 10:19 AM
    Large
    Large Red
    I'm getting the rest of my lift and ordering one anyway. Btw mines 3" lift.
  3. Dec 10, 2011 at 10:22 AM
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build
    its not going to hurt to get one. plus they are not that expensive so if it gives you piece of mind then the few extra dollars will be worth it. another thing ithat it will help with is the take off shudder that lifted trucks can get. so it can help smooth that out, that is the main reason why i purchased them for my last truck. easy 5 to 10 min install, will actually take you longer to get your cardboard placed under the truck then it will to do the job. JUST MAKE SURE YOU USE A JACK STAND ON YOUR DRIVESHAFT!!!!
  4. Dec 10, 2011 at 10:27 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    this^^^^^
