Cartista Tacoma A/C and Warning Signal Reformat--Gen 3
Discussion in 'Product Reviews' started by Sand Shark, Apr 17, 2017.
  1. Apr 17, 2017 at 10:14 AM
    Sand Shark
    Sand Shark [OP] I dont pub crawl.when I do,I use pub crawl control
    Erich
    Phoenix, AZ
    2017 Blazing Blue DCSB Off-Road (yes I get dirty)
    REI VIP Parking Pass,Pavement Avoidance System
    I bought a Carista from Amazon ($39.99) to see if I could reprogram some of the features of the trucks A/C and lighting. I also wanted to stop some of the nuisance warnings. It worked great.
    Below are the items that you can change on your Gen 3.using the Carista OBD II fob with my Galaxy pad. I also plugged it into my 2008 4-Runner. Not as extensive but still a good list there. You also can run engine faults and monitor some outputs from the engine. I purchased the 1 ye version fro $29. I was thinking about reprogramming other cars.
    Doors and Warnings
    Blink turn signals when locking/ unlocking with remote
    Beep when locking / unlocking with remote
    Warn (beep) when the door can’t be locked because it is open
    Panic function on remote
    Relock doors automatically if you unlock but not open a door
    Re-lock doors automatically if you unlock, but don’t open a door within .5 sec t o10 sec
    Unlock doors via remote (all or Drivers)
    Unlock doors via physical key (1 press or 2 press)
    Seat belt warning Ding driver
    Seat belt warning Ding passenger
    Lane change turn signal auto flasher count
    Remote low battery warning
    Mute parking sensor when stationary for more that 3 sec
    Parking sensor beep volume
    Activate parking sensors in neutral
    Enable rear parking sensors when Drive or neutral
    Dash Display mode
    Daytime running lights
    Coming home lights duration
    Auto headlights activation threshold
    Instrument lights dimming sensitivity
    Instrument lights restore sensitivity
    Turn on interior lights when you unlock doors
    Turn on interior lights when smart key is in range
    Interior light control
    Environmental Sys
    Temperature Dial Calibration
    Auto On A/C when AUTO button pressed (if needed)
    Deactivate front defroster when AUTO button pressed
    Open vents to outside air when ignition is turned off
    Fan reaches its target…Slow, Med, Fast
    peavey02 and Oldman808 like this.
