Carwash and Antenna
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JDCPA, Apr 28, 2012.
  1. Apr 28, 2012 at 10:48 AM
    JDCPA
    JDCPA [OP] Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    Stupid me went to a "Soft Cloth" Car Wash yesterday because it was severely discounted after buying gas. Sucker ripped the antenna off right at the base. Now I have the joys of threading another antenna cable into the passenger compartment and the back of the radio unit.
    Joy, joy, joy!
  2. Apr 28, 2012 at 10:51 AM
    mcdowell
    mcdowell My name is Mudd
    mike
    mobile al
    2011 prerunner SR5
    2in Toytec leveling kit TSB 4 leafpack 130w KC driving lights Wsetin 3 tab lightbar Black headlights Trex eyelids TRD sport wheels Firestone MT Hood protector Vent visors Tube stepbars Colormatch grille
    Ummm aahh lets see. Its a great oppertunity to work on your truck?
  3. Apr 28, 2012 at 10:54 AM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Lesson learned, unscrew it before you go in. Takes 5 seconds.
  4. Apr 28, 2012 at 10:59 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    There's a connector for the antenna behind the passenger kick panel.
    If you get the OEM antenna, you won't have to do more than pull the kick panel, glove box, and the wheel well liner... maybe the wiper cowling, I didn't trace the cable.
  5. Apr 28, 2012 at 11:09 AM
    JDCPA
    Jim
    SW FL
    Good to know. I was going to use the OEM to keep things simpler.
    Thanks!
  6. Apr 28, 2012 at 11:10 AM
    Tacoma Mike
    Southern Maine
    if it snapped off at the base just get the broken piece out and install a new mast. I do this all the time.
  7. Apr 28, 2012 at 3:31 PM
    JDCPA
    Jim
    SW FL
    I wish it were that easy. I had gotten tired of the mast coming loose and used some blue Locktite to keep it from backing out. It snapped the socket completely out. Will need to replace the entire base.
  8. Apr 28, 2012 at 6:00 PM
    Tacoma Mike
    Southern Maine
    Well blue locktite does put a damper on things don't it. :confused: I would get a 2012 mast as it has a different base that comes with it's own wrench. I'm waiting for a 12 to come in with an extra mast and I'll be shortening it and putting it on mine.
