Carwash/wetness problem. Anybody else?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CalvaryBlueTRDSportA.C., Apr 3, 2022.
  1. Apr 3, 2022 at 8:26 AM
    CalvaryBlueTRDSportA.C. [OP] Well-Known Member
    Jordan
    '19 Cavalry Blue 6spd TRD Sport Access Cab
    Eibach suspension, nitto ridge grapplers (factory size with 1" spacers), Ripp coils, k&n blackhawk intake, magnaflow exhaust, magnuson sc, j&l catch can, optima yellow battery. ARB onboard twin woth tank ordered. ECGS front and rear with 5.29 and arb lockers coming next.
    My tacoma is a 2019. Bought it new and have only had one issue where it runs rough and throws codes. Previously I thought it was bad gas at the station but yesterday I ran through the car wash w/o getting gas and had the same issue occur. My truck runs like garbage, check engine comes on and shows a 'lean' code. Something (not the intake) is getting wet. I don't understand why this doesn't happen driving in rain. I havnt crawled around and looked yet for the issue, but curious if anybody else has had an issue here? Solutions?
    I've got about 200miles remaining under warranty..
  2. Apr 3, 2022 at 8:32 AM
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    Rain isn’t the same as high pressure water spraying up from the bottom. I’d get it in fully explain the issue while it’s running crappy and try to get it fixed under warranty. Chasing that kind of electrical issue could be pretty expensive. Older cars that could be a plug wire getting wet shorting, but on new stuff it’s all the more to diagnose since everything is so connected by computer.
  3. Apr 3, 2022 at 9:11 AM
    Jordan
    Yea I get the rain vs pressure thing. I had it in once when this was going on but at that time I and the tech I talked to both suspected the gas. They ran codes, which is how I knew it to be a lean code, made sense to the potentiality of the gas issue. Went to the gas station and filled up (had only filled to roughly 1/2 on the 'bad gas'). The issue immediately went away. I now suspect coincidental timing on that occurrence, as the wetness would have had time to dry out at that point.
    This time though the only variable was the car wash. I just looked it over visually and I see nothing obvious. Fuse/relay boxes and intake are all bone dry.
    Dealer ship is my first call in the morning for sure. I am skeptical they will find anything, if it requires pressure to create the issue and not just rain, its gotta be a tiny split/crack/gap they would be looking for. (I would think) I'll be pushing for a new engine harness if that is the case.
  4. Apr 3, 2022 at 10:56 AM
    Mike402
    Mike402 Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
    Wish you the best of luck, but seriously doubt that is going to happen.
  5. Apr 3, 2022 at 11:02 AM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    you got the fuel pump recall done, right?
    roboturner likes this.
  6. Apr 3, 2022 at 11:31 AM
    Jordan
    Yes I had the recall done.
    I doubt they will want to do the harness as well.
  7. Apr 3, 2022 at 11:47 AM
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    Why can't it be the wide open K & N Blackhawk intake you have?
  8. Apr 3, 2022 at 11:49 AM
    TacoSupremo19
    NJ
    And what exactly is the code your getting?
  9. Apr 3, 2022 at 12:48 PM
    Jordan
    I don't know that id call it 'wide open' it is contained within a box still. I just went through the wash again to see what was wet when i came out the other side. There were some sprinkles in the intake box but id hardly call it wet. There is still visible dust around the intake that clearly was not made wet. I have had other vehicles with more aggresive more open intakes that never had that happen. I would think it would happen in the rain also if the intake were involved. Not saying it couldnt be but i feel like it is not likely. The front half of the engine was dripping wet and there are a couple of connections that are soaked on a couple of sensors(?) .
    Don't recall the code numbers but they were bank 1 lean, bank 2 lean.
  10. Apr 3, 2022 at 1:05 PM
    Tacoboutkewl
    Tacoboutkewl Well-Known Member
    could it be a tiny hole in one of the hoses, causing a vacuum leak?
  11. Apr 3, 2022 at 1:07 PM
    Tacoboutkewl
    * tiny hole/crack in one of the vacuum hoses, causing a leak *
  12. Apr 3, 2022 at 1:15 PM
    Jordan
    It's the filter.. I'm am idiot guys.. took it over to the shop to blow off the dust and that made it very evident. Mist came shooting out of it and the inside filled with soap foam. It honestly felt basically dry. I had considered that could be the issue but I never even experienced that on my talon and that has a legit hole through the hood over the intake, so I dismissed it as an option. Go ahead call me a noob.
    Self induced issue.
  13. Apr 3, 2022 at 1:41 PM
    Tacoma091919
    Tim
    2019 OR DCLB
    I’d just be happy AF it’s something that simple. Chasing that kind of issue would be a freaking nightmare unless you had a really smart and methodical tech trying to figure it out, and it would probably take some time.
    Don’t think I’d want a mod that caused issues with water spray though. I don’t go bombing through puddles / mud bogs but still.
  14. Apr 3, 2022 at 1:52 PM
    4x4spiegel
    4x4spiegel Well-Known Member
    another DIY fix , excelente !
  15. Apr 3, 2022 at 2:58 PM
    TacoSupremo19
    NJ
    If the condition does present itself again, you might need to clean your MAF. Maybe not though as that sucker should be clean as a whistle now lol. Glad you found the problem, and, more importantly, reported back the conclusion.
  16. Apr 3, 2022 at 3:13 PM
    Jordan
  17. Apr 6, 2022 at 11:42 AM
    Jordan
    With the filter dried and re installed the check engine was still on. Cleaned the MAF, and now it's clear of codes and running perfect.
