Cascadia Vehicle Tents Group Buy - March 1 through March 16
Discussion in 'Group Buys' started by MTgirl, Feb 9, 2013.
Thread Status:
Not open for further replies.
  1. Feb 11, 2014 at 2:08 PM
    #1961
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    Yeah glad I could help, sorry I made it sound confusing.
  2. Feb 11, 2014 at 2:19 PM
    #1962
    BamaToy1997
    Bill
    Navarre, FL
    I'm going to be waiting to get the Mt Shasta with Annex..... :popcorn:
  3. Feb 11, 2014 at 2:22 PM
    #1963
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I'm either getting the CVT Mount Shasta or the Tepui Autana. Both are essentially the same.
    Mount Shasta is slightly lighter while the Autana is thinner when closed and wider when open.
  4. Feb 11, 2014 at 2:46 PM
    #1964
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    So many decisions. I think CVT is the way to go.lol
  5. Feb 11, 2014 at 2:47 PM
    #1965
    PcBuilder14
    Brent
    Nor Cal
    I'm kind of leaning towards the CVT because it looks like the Tepui annex doesn't have door options on all 3 corners like CVT. Only a door right in front of the ladder.
  6. Feb 11, 2014 at 2:47 PM
    #1966
    tacodane
    Dane
    Ya I noticed that
  7. Feb 11, 2014 at 3:49 PM
    #1967
    GANGGREEN
    GANGGREEN Well-Known Member
    Seems like shipping is less for with Tepui and it looks like some of the models are an inch shorter when closed. I'm still completely undecided but it's not a bad problem to have since both seem to be good options.
  8. Feb 11, 2014 at 4:16 PM
    #1968
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Just a guess but I'm thinking an inch shorter when closed means not as thick of a mattress, or the measurements are a little off from someone's website.
    The thickness when closed depends on if you have anything else in it. I leave 2 pillows, 2 sleeping bags, and a blanket in it and I leave my annex attached. So if I removed all that my closed height could be an inch shorter, but who cares.
  9. Feb 11, 2014 at 9:45 PM
    #1969
    phisohex
    phisohex Well-Known Member
    pat
    Rocky Mountains, Colorado
    2002 Double Cab TRD Tacoma
    Great, First i just had to decide which CVT tent to get, now there is the Tepui group buy going on as well.. :goingcrazy:
    Just have to remember with group buys, the more you buy, the more you SAVE!
  10. Feb 11, 2014 at 9:51 PM
    #1970
    bkrdave36
    bkrdave36 Well-Known Member
    Dave
    Wittmann,AZ
    06 Prerunner Double Cab Black
    Front OME Springs, Upper Control Arms, Icon Stage 3 Rear Leaf Springs, Durobump bump stops,Bilstein 5125 shocks, BFG All Terrain KO2 Tires, Avid Light bar and step rails, Victory 4x4 bed rack with Tepui Ayer Rooftop Tent, Anytime Fog light mod, Outside Air Temp Gauge mod, ImMrYo Rearview Mirror mod, Chinese Knockoff LED lights, Body Armor 4x4 Offroad Swingout rear tire carrier and bumper, Victory 4x4 Bed Stiffeners, Rattle can Custom Camo paint stripe, Truxedo Lo Pro tonneau cover, various Blue Ridge Overland Gear storage solutions in cab, thats it so far .... to be continued!
    Tepui has the "non-collapsible" ladder available as an option.
    I have a Tepui Ayers tent and it works very well. I want to go bigger eventually as the Ayers is mostly a good tent for a single person. No matter who the manufacturer is, I would suggest marking the tent floor dimensions out on the floor and laying down in those to see if they will provide you with the needed space. It would suck to get the wrong size tent, even if it was a great deal!
  11. Feb 11, 2014 at 11:04 PM
    #1971
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    how the hell? explain this for me lol. The cover cant seal all the way the the annex still mounted. Atleast... with that track part it slides in. but then, your annex is only supported on 3 sides instead of 4.
  12. Feb 12, 2014 at 4:54 AM
    #1972
    Cascadia Tents
    Cascadia Tents Well-Known Member Vendor
    Bobby
    Bend, Oregon
    Betty White
    Yes it will. We will start March 5th-31st
  13. Feb 12, 2014 at 4:57 AM
    #1973
    Cascadia Tents
    Bobby
    Bend, Oregon
    Betty White
    Thank you for mentioning this. This is something we also recommend. Always make sure of the size you are buying to fit your needs and/or future needs.
  14. Feb 12, 2014 at 4:59 AM
    #1974
    Cascadia Tents
    Bobby
    Bend, Oregon
    Betty White
    I am glad you noticed. Apples for apples is always best. The fabric of the annex also. All of the bars on the interior of the tents have been upgraded also. Plus we have a few more features coming on them. Will have more photos and a better lay out at start of the group buy.
  15. Feb 12, 2014 at 5:06 AM
    #1975
    Cascadia Tents
    Bobby
    Bend, Oregon
    Betty White
    We also did have issues last year with about 40 telescoping ladders. We have chose to stick and go back with the original ladders that slide. The issues with telescoping is something we do not want as this is where a lot of weight goes. The dirt on them also creates problems. There will be better ones coming. They have not been around a long time and they are always getting better.
    Thank you for the compliments. I love doing it and really enjoy meeting all of you.
  16. Feb 12, 2014 at 6:08 AM
    #1976
    Infra
    Az
    No sir. But if there are ppl close to you who order, you can all have them shipped to same place & split the shipping costs.
  17. Feb 12, 2014 at 6:29 AM
    #1977
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    This is what I'm very interested on... you say the new styles.... :popcorn:
  18. Feb 12, 2014 at 8:12 AM
    #1978
    BamaToy1997
    Bill
    Navarre, FL
    :rockband::rockband::rockband::rimshot:
    Can you tell I am excited?
  19. Feb 12, 2014 at 8:35 AM
    #1979
    toyohtadude
    toyohtadude Well-Known Member
    Eric
    Austin, TX
    2017 4x4 Tundra SR5 CrewMax
    Bone stock
    I'm glad it will run to the 31st. I'm in a small quandary here. My company pays our bonus out each year around the end of March to the beginning of April. I won't know the amount until it is paid but I have a couple priorities I need to take care of first and then, if the bonus is enough, buy the Mt. Shasta with the extra. (This is supposed to be a *good* year too!) Some years it is paid in March, some in April. If it is April payout, I'm screwed because I'm not sure I'll have enough to accomplish all goals. I'm hoping for March! I *really want* the Shasta!
  20. Feb 12, 2014 at 8:56 AM
    #1980
    RigidTaco
    RigidTaco Well-Known Member
    Kelowna, BC
    24 Sport Premium
    Same here brother, my boss just told me ill see mine on the 20th of Feb so im golden.... thing is my priorities are backwards as the RTT is first on the list haha
Thread Status:
