Casper's Broken Down old Grumpy Assed Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Casper66, May 1, 2017.
  1. Sep 20, 2017 at 7:12 AM
    #1081
    Tactical_Panda
    Tactical_Panda Armchair Anarchist
    Tim
    Fredericksburg, VA
    2015 Tacoma Double Cab, Off-Road Edition
    AJT Designs Shifter AJT Designs Battery Hold-Down ARB Awning 2500x2500 ARB Twin Compressor w/ Slee Offroad Mounting Bracket Avid Brush Bar Avid Step Bars Black Rock Wheels Series 997 Type 8 Circuit Breaker/Relay Panel Custom TRD Decals Bulletproof Fabricating Raptor Grill Bulletproof Fabricating Cooling Panel Bulletproof Fabricating Tow Hook Duluth Trading Company Dog Hammock Exhaust Breather Mod eBay Special 3-Gallon Air Tank Expedition Essentials TPAM EZ Down tailgate damper Flagpole Mounts, Dual Foglight Mod Front Camera Rear Camera; full time available General Grabber tires Goat Armor Hella Supertone Horns Iggy Switch Panel Icon Dynamics Stage 3 Suspension Katskin Leather Interior KickAss camp shower LED Bed Lights LED Interior Lights Midland MXT275 GMRS Two-Way Radio OEM Audio Plus Reference 500 audio upgrade Plano Cases. 42" roof mounted, X2 Pop-N-Lock Tailgate Handle Prinsu Cab Rack Prinsu-like Shell Rack Redline Tuning Hood Struts Rigid Industries 40" Light Bar Rigid Industries Ditch Lights Rigid Industries Spotlights Toyota Bed Step UltraGauge EM Plus v1.4 Vixen Air Horns, Four-Trumpet Whole bunch of decals worth about 5HP each Yakima Road Shower, 10-gal
    FIFY
  2. Sep 20, 2017 at 7:33 AM
    #1082
    Casper66
    Casper66 [OP] grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    ? Just skids. The other truck was a 4 cyl so to make the trans skid fit I had to cut it and add 2" I just cut the 2" out and burned it back together idk what's fancy simple stuff really
    Kemosabe and inesshell[QUOTED] like this.
  3. Sep 29, 2017 at 8:38 AM
    #1083
    Casper66
    Culpeper, Va.
    piddly stuff
  4. Sep 29, 2017 at 5:22 PM
    #1084
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Great write up.
    Could I just sand with 1500 grit and reclear to fix the shitty clear coat on my flares? Also, what's the reducer that you mentioned?
    Casper66[OP], Kemosabe and Wild Crow like this.
  5. Sep 30, 2017 at 8:27 AM
    #1085
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
    I wet sanded once with a 800grit paper to correct a clear coat and it got the job done nicely, but I'll let @Casper66 answer on it since he is a pro!
    Casper66[OP] likes this.
  6. Sep 30, 2017 at 5:38 PM
    #1086
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    Great write up! I'll be saving that one for later! Now just out of curiosity. If it were on a metal part of the body like the fender and a big portion was worn down to bare metal, would u use an adhesion promoter or a self etching primer? I'm assuming that you used an adhesion promoter due to the fact it was plastic?
  7. Oct 1, 2017 at 5:47 AM
    #1087
    Kemosabe
    Louis
    I don't remember the name on the spray bomb but my father is using some kind of zinc primer on bare metal, to give adhesion to the primer. I don't know if it is really necessery and if @Casper66 does use it tho...
  8. Oct 1, 2017 at 3:50 PM
    #1088
    Casper66
    Culpeper, Va.
    piddly stuff
    Just use a mild enamel reducer you don't need anything harsh. 1500 is ok but if the clear is failing you'll have to sand back to where it stops peeling and feather all the edges really well. Base coat is fairly easy to sand through so be careful. For reclearing 600-800 is good only problem is it'll sand through the base easier
  9. Oct 1, 2017 at 3:56 PM
    #1089
    Casper66
    Culpeper, Va.
    piddly stuff
    We use adhesion promoter on metal and plastic. If you have a large area worn down to bare metal I'd prime first and block the area to insure it's straight and you don't have any lows then spray with adhesion promoter and color. Do not use adhesion promoter if only reclearing it sometimes discolors the clear
    Bocsy44[QUOTED] likes this.
  10. Oct 1, 2017 at 3:57 PM
    #1090
    Casper66
    Culpeper, Va.
    piddly stuff
    We don't we usually use a good urathane primer
  11. Oct 1, 2017 at 4:01 PM
    #1091
    Justanotherhemi
    Justanotherhemi Space Cowboy/Ninja
    Rick James
    Area 52 (because area 51 was full)
    Intelligent Life Exists
    Just got caught up. This new truck is looking great @Casper66 !
    BTW the new avatar looks cool :thumbsup:
    Kemosabe and Casper66[OP] like this.
  12. Oct 1, 2017 at 4:10 PM
    #1092
    Casper66
    Culpeper, Va.
    piddly stuff
    Don't use an adhesion promoter to just spray clear as it can discolor it. If you have a place that's not visible or something laying around you can spray you can try a spot with and with out and see what happens
    inesshell and Kemosabe[QUOTED] like this.
  13. Oct 1, 2017 at 4:35 PM
    #1093
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    Thanks for the reply and info. I still have no idea what a reducer is, though. :rofl: Would that be like acetone, isopropyl alcohol, mineral spirits, xylol?
  14. Oct 1, 2017 at 4:51 PM
    #1094
    Casper66
    Culpeper, Va.
    piddly stuff
    Mineral spirits ar ok but I prefer a mild reducer aka paint thinner just get a small can of enamel reducer/ thinner or if you feel more comfortable with it they make a pre paint cleaner that you can even get in aerosol. I was in westmoreland camping all weekend sorry it took so long to reply. James was there with us check out the camper build
    inesshell and Kemosabe like this.
  15. Oct 1, 2017 at 5:01 PM
    #1095
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    Thanks again.
    Colonial Beach is in Westmoreland county. I'm sure you weren't that far from me.
  16. Oct 1, 2017 at 5:04 PM
    #1096
    Casper66
    Culpeper, Va.
    piddly stuff
    Westmoreland State park I just posted about it in the camper build
    Kemosabe likes this.
  17. Oct 1, 2017 at 5:16 PM
    #1097
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    Yup. Just googled it, and it's 16 miles from my house. Looks like a fun little trip. Maybe I'll get motivated enough to drive out and look around one weekend.
  18. Oct 1, 2017 at 5:22 PM
    #1098
    Casper66
    Culpeper, Va.
    piddly stuff
    Thanks! Truck pretty well done for now. I need to consentrate more on the camper. Hell I've already got everything on this truck the other one had plus a bit more
  19. Oct 4, 2017 at 4:37 PM
    #1099
    Casper66
    Culpeper, Va.
    piddly stuff
    Ok so the gathering of fluids and materials to change all fluids has begun, I have a fumoto valve and just ordered 4 qts of Redline MT-90 for the transmission and t-case now I'll order diff fluids when I figure out which ones to get.
    Kemosabe and Justanotherhemi like this.
  20. Oct 4, 2017 at 5:48 PM
    #1100
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    I run Redline in my diff, as well as the tranny.
    TacoCat and Casper66[QUOTED][OP] like this.
