Casper's DIY Paint Repair
Discussion in 'Detailing' started by Casper66, Sep 28, 2017.
  1. Jul 9, 2018 at 6:13 PM
    #61
    Casper66
    Casper66 [OP] grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    Ideal? 65-80 degrees and fairly low humidity. You can help it a little by having a fan move air over it. Not like a wind but just a gentle breeze. I/ve painted in temps from 22 degrees (PITA) to around 120 degrees (miserable) and in 30 years this is the first time I've had this happen. That's spraying all types of materials. You can spray something one day and have unfavorable results and spray with the same materials the next day and have it come out beautiful. Where you live a nice warm day with moderate to low humidity would be great.
  2. Jan 28, 2019 at 1:44 PM
    #62
    Inkedgenius85
    Inkedgenius85 Well-Known Member
    Danny
    Turner, OR
    2014 MGM TRD Sport DCLB
    17x8 Vision Raptors Falken Wild Peak 265/65/17 20% tint DeeZee bed mat Center console holster Alla lighting 3000k led fog light bulbs Alla LED license plate bulbs JDM Astar led reverse light bulbs Bilstein 5100s all around 1/4" Taco spacer HeadStrong 2" lift coils HeadStrong Progressive AAL
    Perfect write-up. I've had a blemish like that on one of my fenders since I bought it. I'll definitely be using this to fix it once it warms up!
    Casper66[OP] likes this.
  3. Jan 28, 2019 at 1:58 PM
    #63
    Casper66
    Culpeper, Va.
    piddly stuff
    It’s still looking good after a year and a half or so
    Inkedgenius85[QUOTED] likes this.
  4. Mar 24, 2021 at 8:16 PM
    #64
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Who here has used automotive flat back paint?
    Recommendations?
  5. Mar 25, 2021 at 3:54 AM
    #65
    Casper66
    Culpeper, Va.
    piddly stuff
    “Hot rod black” I’ve used some no particular brand it’s been a while. You can also mix in deglosser with regular paint or clear coat
    Rakso[QUOTED] likes this.
  6. Jun 1, 2021 at 12:04 PM
    #66
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    @Casper66 , I know this is an older thread, but I'd like to know if you painted the entire fender flare. I didn't see any pics of where you taped off just the effected area.
  7. Jun 1, 2021 at 3:48 PM
    #67
    Casper66
    Culpeper, Va.
    piddly stuff
    I wet sanded the whole flare then taped the whole flare off. I sprayed color over the repaired area until covered good then sprayed the whole flare with clear. I know the white is single stage but with aerosols doing a blend and clearing is the easiest way[/QUOTE]
