Cast Aluminum Steps
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Unchained 5150, Sep 6, 2021.
  1. Sep 6, 2021 at 5:40 AM
    Unchained 5150
    Unchained 5150 [OP] Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Got a sweet deal on a set of these, only issue is no bolts. Being in New England do they make a better in grade 8 or something like that I could use?
  2. Sep 6, 2021 at 5:42 AM
    Unchained 5150
    Rick
    Auburn Ma
  3. Sep 6, 2021 at 5:52 AM
    Unchained 5150
    Rick
    Auburn Ma
  4. Sep 6, 2021 at 6:25 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Living here in New England as well, I'd go with stainless steel. Grade 8 means nothing without considering the corrosion resistance.
    Check out:
    https://www.mcmaster.com/hex-bolts/...ngth-17-4-ph-stainless-steel-hex-head-screws/
    OR:
    https://www.mcmaster.com/hex-bolts/...stant-high-strength-bumax-88-hex-head-screws/
    Galvanized steel won't fare to well in the long run.
  5. Sep 6, 2021 at 6:35 AM
    Unchained 5150
    Rick
    Auburn Ma
    I’m driving right now is there anyway you can link me to one bolt that I need
  6. Sep 6, 2021 at 6:35 AM
    Unchained 5150
    Rick
    Auburn Ma
    And is there something I can find at Lowe’s or a Home Depot
  7. Sep 6, 2021 at 7:20 AM
    CT Yankee
    CT
    Can't help you there. This is a fastener I would NOT buy from a big box store that typically sells Chinesium. Besides, I don't know what size bolt you need, so you'll have to make that determination. You should use the same quality nuts & washers.
  8. Sep 6, 2021 at 7:37 AM
    Unchained 5150
    Rick
    Auburn Ma
    Thanks just going to order the hardware kit then
