Cast Iron Exhaust CutOut - $35 Shipped
Discussion in 'Buy / Sell / Trade' started by Foxer, Jan 10, 2012.
  1. Jan 10, 2012 at 7:02 PM
    Foxer
    Foxer [OP] Well-Known Member
    U.S.A.
    Access Cab PreRunner
    Bought this 10 years ago and never installed it...
    Basically this is welded in front of the muffler and includes a dash pull switch that allows you to bypass the exhaust when pulled for added power. :D
    U.S. Made.
    $35 Shipped CONUS
    In San Diego if u wanna pick up.
  2. Jan 11, 2012 at 3:45 PM
    Foxer
    U.S.A.
  3. Jan 11, 2012 at 3:46 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Just a bypass for the muffler or the full exhaust?? :notsure:
  4. Jan 12, 2012 at 6:17 PM
    Foxer
    U.S.A.
    Bump...probably all u can bypass is the muffler since the cats are so close to the headers...on a Tacoma at least.
  5. Jan 13, 2012 at 5:47 PM
    Foxer
    U.S.A.
  6. Jan 13, 2012 at 5:54 PM
    DeadWeasel
    DeadWeasel ಠ_ಠ
    Rex
    Portland, ME
    09 : 4x4 : 2.7L : 5spd
    32" BFG ATs, Removed 2nd air filter, Brighter Reverse Lights, ARE Cap, LED maps/dome, ScanGauge II, zXe headlights
  7. Jan 13, 2012 at 6:14 PM
    Foxer
    U.S.A.
    Not sure I purchased this for a Miata I used to own but never installed it... found it in my closet the other day... I know it will fit the exhaust pipe size on a Tacoma...
  8. Jan 13, 2012 at 8:32 PM
    96 tacomaPtown
    96 tacomaPtown Well-Known Member
    Bryan
    Oregon
    96 ext cab 4x4 taco
    3 inch spacer lift,pro comp addaleaf, 1 inch diff drop kyb shock/struts, Lc engineering header, stock muffler, hollowed cat, 2 1/4 exhaust, o2simulator , 31 10.50 15 wranglers on stock. Hella 500 headlamps, bug gaurd, vent visors, bed caps, bed liner, Volant cai intake.
    it might trip a code because it would just open the exhaust up and decrease amount of pressure needed for the egr system.it would just bypass your muffler you would put it right behind the second o2 sensor. hot rods have these, they used them for racing because they make your vehicle allow all the exhaust out with out restriction of the muffler and excess pipeit makes it so loud they had to have the bypass for sound requirements.
  9. Jan 13, 2012 at 8:55 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    used to have these on my 05 pontiac GTO
    they are really fun...
    Some asshat in a ricer gets next to you and starts revving their engine and you just open them up and the ground would shake... at idle...
    free bump
  10. Jan 14, 2012 at 5:42 PM
    Foxer
    U.S.A.
  11. Jan 15, 2012 at 11:51 AM
    Foxer
    U.S.A.
  12. Jan 16, 2012 at 4:48 PM
    Foxer
    U.S.A.
  13. Jan 17, 2012 at 8:29 PM
    Foxer
    U.S.A.
