Cast Iron Help Please
Discussion in 'Food Talk' started by 2001Tacoma, Mar 17, 2024.
  1. Mar 17, 2024 at 4:39 PM
    2001Tacoma
    2001Tacoma [OP] Well-Known Member
    2019 SR I4
    I have had this for many years, got it used. I believe I treat it correctly, no soap, use oil. For a while now it has developed this rough area going around the edge. I have attached 2 pics. One of them has a blue arrow pointing to the area I am talking about. Does anyone know what is causing this ? How do I get rid of it ? What ever it is it does flake off on its own but I can not easily get it off and is hard as nails. Just before taking this pic I washed it with hot water and rubbed it with salt. Thank you for any help.
    clenkeit likes this.
  2. Mar 17, 2024 at 4:46 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Looks like excess oil that enameled on the outside. Nothing really to worry about but it’s a sign that you’re over-oiling the pan before running it through heat cycles. You should only be using a small amount of oil with a high smoke point to coat the pan. It’ll continue to build up but it’s not easy to take off unless you get aggressive with it- nothing to worry about though.
  3. Mar 17, 2024 at 4:46 PM
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    That's oil that has turned into a polymer under extreme heat.
    You can get rid of it with wet/dry sandpaper, barkeepers friend or even coarse sea salt flakes and some elbow grease.
    It won't be detrimental to your seasoning layer either. Just go ultra thin on the oil next time you go to season/burn it
    ColoradoTJ and 2001Tacoma[OP] like this.
  4. Mar 17, 2024 at 4:47 PM
    GHOST SHIP
    GHOST
    mtip and 2001Tacoma[OP] like this.
  5. Mar 18, 2024 at 3:37 AM
    2001Tacoma
    2019 SR I4
    @GHOST SHIP thank you, I will use less oil from now on, im going to go take a look at that thread, thank you.
    @Clinch Mountain Preacher Thank you, I think I am going to try the wet sand paper method, maybe put it on my random orbital,,,easier then elbow grease :) Thank you.
  6. Mar 18, 2024 at 4:01 AM
    soggyBottom
    soggyBottom Well-Known Member
    If you're not sure if you have too much oil when seasoning it, you have too much oil.
  7. Mar 23, 2024 at 5:12 AM
    soggyBottom
    I just finished resurfacing one of my carbon steel pans. In the past I tried doing slow on the oven.this time I said, f it and went full retard on a gas burner outside. I also sanded it to 800grit. This is supposed to be a good roughness for polymers to adhere to. I followed it up with some deeper scratches that I'm hoping with further help.
    For each coating, I poured a put a teaspoon and quickly wiped it with a paper towel.
    Not sure if the scratches will help or hinder or if I'll even notice.
    2001Tacoma[OP] likes this.
  8. Mar 23, 2024 at 11:00 AM
    2001Tacoma
    2019 SR I4
    Well everyone thank you for all the help. I ended up using this Disc kit in my drill to clean the pan. Taking my time it took about 30 minutes to accomplish. Thank you all for the time and help.
  9. Mar 23, 2024 at 2:15 PM
    soggyBottom
    Looks great! Post a followup after it's seasoned.
  10. Mar 24, 2024 at 2:36 PM
    2001Tacoma
    2019 SR I4
    @soggyBottom Thank you for asking, here is a pic after first seasoning. I think it would be good to do another seasoning before using it. Thank you all for helping. :)
    soggyBottom and wilcam47 like this.
  11. Jul 23, 2024 at 10:55 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    that is cool pan!! i just run that wad of steel mesh that comes in one of those BBQ grill grate scrubbers. it knocks off all the high spots created by carbon build up. then it is just back to business as usual. if it gets really bad, i like popping it into my outdoor propane grills set on the highest temp. in about 30 minutes, i let it cool. when i tap on the pan with something like a rock..the stuff falls off like black snow. then i re-season it. since i started periodically scrubbing around the perimeter with the steel mesh, i have had zero issues.
    and i sometimes wash my pan with dishsoap. soap is no longer lye based, so no issues.
  12. Jul 23, 2024 at 11:04 AM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    to work that off you can use steel wool, or some sand paper, but ive also knocked down some of that stuff with the "chainmail" scrubbers as well but im also not against using one of the angle grinder scrubbers to buff down the crap!
  13. Jul 23, 2024 at 1:33 PM
    Stuck in VT
    Stuck in VT Well-Known Member
    Utah
    2019 SR SX MGM
    The after using it picture.
    Did mine today it looked wrecked! Enjoyed a couple of burgers today with caramelized onions, full recovery.
    God these pans can look ugly and be brought back to life!
