Caster #’s
Discussion in 'Suspension' started by Jpiskura, Jan 25, 2020.
  1. Jan 25, 2020 at 6:15 PM
    Jpiskura
    Jpiskura [OP] Well-Known Member
    So, after I installed my new CO’s I had it aligned again and the the tech said that he couldn’t get the caster on one side past 2.7.... the other side came in at 3.4-3.5 truck drives and feels fine suspension wise. Should I leave it or try and take it somewhere else in the spring..? Like i said it doesn’t pull one way or the other, steering wheel tracks fine and no vibes or shimmy’s of any kind. How critical is the 3.5 number....? Thanks in advance!!
  2. Jan 25, 2020 at 6:16 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Which CO's did you install? Did you lift the truck?
  3. Jan 25, 2020 at 6:35 PM
    Jpiskura
    Ya, sorry your right... no facts posted. It’s a 13 with Fox 2.5DSC and TC UCA and LCA, lift is prolly around 2.75-3..?
  4. Jan 26, 2020 at 10:32 AM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    I just want to add to the whole caster debate. It seems that most people push the idea that more is better. There is some draw backs to high caster angles. The greater the caster angle the greater the steering effort and stress on steering components at slower speeds that significantly increase with larger tires as well as lower tire pressures. For those that trail ride the rig especially in the rocks or slower speed activities may benefit from caster angles in the 1.5 degree range. Yes there are draw backs to lower numbers but castor angles should be chosen based on how the vehicle is used.
    burrito782 and Georgia Native like this.
  5. Jan 26, 2020 at 5:55 PM
    Jpiskura
    Well, that’s kind of why I posted because if it’s not a huge deal on my DD then I’m not gonna go crazy and chase a number that everyone seems to seek...
