Caster adjustment with uca's
Discussion in '1st Gen. Tacomas (1995-2004)' started by Deathbysnusnu, Nov 11, 2013.
  1. Nov 11, 2013 at 7:10 AM
    Deathbysnusnu
    Deathbysnusnu [OP] Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Can caster be adjusted just from the uca's without screwing up the rest of it?
    Using LT Racing uca's and have frozen cams in the lca's, caster is at about +1.7, really could use some more, at highway speeds the tracking sucks pretty bad.
    Is all this dependent on the current position of the frozen cams?
    I know I'm beating a dead horse, I can see the lca's being cut off in the very near future and replacing the bushings and cams, but I have to ask...
  2. Nov 11, 2013 at 7:52 AM
    offrdmania
    offrdmania Taco Wagon
    Templeton, Ca
    96 Tacoma LX 4 banger
    Check your air pressure in the tires first to make sure your pull isnt from that. Im not familiar with LT racing but I would check with them to see if they incorporated adjustment into the arms for caster. Usually caster is adjusted in a lca because adjusting caster in an upper will also effect the camber
  3. Nov 11, 2013 at 7:54 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Yes you can clock the LR UCA ball joint to increase / decrease caster but it is in set degree increments
  4. Nov 11, 2013 at 8:50 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I gave the wrong numbers, sorry for that. I just returned from the shop and had them print it out for me.
    Looks to be close, I'm thinking I may need a bit of negative toe, or toe in. The shop suggested to try that first as it can be done in the driveway
    Caster 2.52 Left
    2.46 Right
    Camber 0.48 Left
    0.29 right
    Toe-- 0.07 both sides, total of 0.14
    Off to change toe in, I'll report back later...
  5. Nov 11, 2013 at 8:56 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Good call, I did check, they are at 34 psi, new tires, not worn funny at all.
  6. Nov 11, 2013 at 10:45 AM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Update, Success!
    turned tie rod ends 1 turn out both sides.
    75 mph, tracks straight, one finger steering, doesn't pull. Hits bumps, irregularities in the road and returns to center easily.
    Steering wheel sits just slightly to the left, that may be the crown of the road, it's not enough to kick in the OCD so I'm gonna leave it for now.
    Thanks for the input guys :)
