Castle nut stuck on tie rod
Discussion in '3rd Gen. Tacomas (2016-2023)' started by shutupmeg4x4, Nov 20, 2019.
  1. Nov 20, 2019 at 10:38 AM
    shutupmeg4x4
    shutupmeg4x4 [OP] Well-Known Member
    norcal
    18 DCSB V6 4x4 MGM
    tinted windows, scs ray 10's, wrangler duratracs 265/75/r16, eibach pro truck lift, bhlm, rigid fog, RCI sliders, c4 hybrid front
    Soooo while trying to detach my passenger tie rod from the spindle I may have just broken it, the the threads and castle nut are spinning together... Help!
    Do I need to replace the tie rod?
    Any tips of how to DC the tie rod?
  2. Nov 20, 2019 at 10:43 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Cut it off and replace the tie rod end if necessary.
    Also, why are you trying to remove it?
    stealthmode and shutupmeg4x4[OP] like this.
  3. Nov 20, 2019 at 10:45 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Get a pair of vice grips on the threads if possible. Needle nose is best. Paper towel or something can help to reduce damage to the threads but you may have to replace it at the end of the day
    shutupmeg4x4[OP] likes this.
  4. Nov 20, 2019 at 10:45 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Use large vise grips to squeeze the tie rod into the spindle, wedging it into the taper. With that secured, hit the castle nut with an impact and you're done.
  5. Nov 20, 2019 at 10:46 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    It's not broken, the threaded part is just spinning in the joint socket. Sometimes you can get the socket to bind enough to loosen the nut with creative application of a floor jack.
  6. Nov 20, 2019 at 10:47 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    What are you turning the nut with? If a wrench/ratchet try an impact. It may break it loose without spinning the rod.
    Big tall dave likes this.
  7. Nov 20, 2019 at 10:48 AM
    shutupmeg4x4
    norcal
    18 DCSB V6 4x4 MGM
    Install new suspension... Ya that's what I figured but was hoping some tacomaworld guru might have magical trick... Thank you... Any brand recommendations for tie rods?
  8. Nov 20, 2019 at 10:52 AM
    shutupmeg4x4
    norcal
    18 DCSB V6 4x4 MGM
    Ok I'll try all of these recommendations, once I get it apart how would I know if it is broken?
  9. Nov 20, 2019 at 10:58 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Put pressure under the joint with a floor jack and then hit it with an impact gun. Don't pull the trigger and hold though. Pull the trigger for a second, release, pull the trigger for a second and release, do your best to not let the stud spin. This will wreck the ball joint. Also wire brush the threads to clean them before attempting and spray some penetrating oil on it.
    Unless you are replacing the tie rod end don't grab the threads with anything, you will just make it worse.
  10. Nov 20, 2019 at 11:00 AM
    eon_blue
    Azusa, CA
    Sounds like you gooched it, I would plan on putting a new one on when you reassemble it. Outer tie rods aren't that expensive and not something you want to have fail on you while driving.
  11. Nov 20, 2019 at 11:01 AM
    jowybyo
    Joe
    Baltimore, MD
    Are you install new spindles? You don't need to remove the tie rods ends to install new shocks.
    eon_blue likes this.
  12. Nov 20, 2019 at 11:04 AM
    shutupmeg4x4
    norcal
    18 DCSB V6 4x4 MGM
    Well now you tell me lol ... Should I replace the one I fucked up with OEM or is there a good aftermarket option you guys suggest
  13. Nov 20, 2019 at 11:05 AM
    eon_blue
    Azusa, CA
    There's gotta be some online vids of installing shocks on 3rd gens....maybe pull one of those up lol. Definitely don't need to remove the tie rod. If it's anything like 1st gens, you literally just unbolt the 3 top hat bolts and the bottom big bolt that goes through the bottom mount of the shock/coil. Pull it out and put the new one in. Reattach bottom bolt and top 3 bolts and you're done.
  14. Nov 20, 2019 at 11:10 AM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Here is the Toyota guide for the installation of the Pro suspension. You can follow this method and unbolt the lower knuckle, or you can skip that and unbolt the UCA from the spindle. 6 to 1 and half a dozen to the other.
  15. Nov 20, 2019 at 11:11 AM
    shutupmeg4x4
    norcal
    18 DCSB V6 4x4 MGM
    Videos say to DC all that stuff... Either way harms already done just need to fix my current problem
  16. Nov 20, 2019 at 11:18 AM
    eon_blue
    Azusa, CA
    hmm weird...maybe there's something different about your guys' setups. Anyway about it I'd get a new tie rod end for that side just to be safe
  17. Nov 20, 2019 at 11:19 AM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    I'd just plan to replace it.
    You have to pop the upper ball joint, remove the lower shock mount, and the 3 bolts up top.
    Unless you're installing a drop bracket lift which is a whole different pile of problems.
  18. Nov 20, 2019 at 11:25 AM
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
  19. Nov 20, 2019 at 11:25 AM
    cstern1
    cstern1 Well-Known Member
    Caleb
    KCK
    2017 DCSB Sport
    Curious as to what method you used to pop the tie rod.
    After mistakes previously in my life, I always remove the nut all the way before I break the tie rod loose. You can also put it back on by a few threads before separating the joint so it doesn't fall and hit the concrete. Probably doesn't matter. Ball joint is a different story depending on suspension setup.
    I vote for using a floor jack under the tie rod end to press it back in and hope the tension is enough to hold it to loosen the nut. Same method I use to tighten them back up as well.
  20. Nov 20, 2019 at 11:28 AM
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    This is totally normal, don't listen to half these goons telling you to replace it lol. There is not enough tension on the ball joint part of the tie rod so as you spin the nut it spins the ball joint instead of unthreading down the bolt end. Do what some people said put some tension onto that ball joint on that tie rod, by letting the suspension drop out all the way down perhaps. You can then use impact (with a impact drive or hitting the wrench end with a hammer) to loosen the nut.
    If you vice grip the threads and prevent them from spinning you will destroy the threads and the nut cant thread past that point. ... and then you will be forced to buy a new tie rod.
