Cat and 02 sim
Discussion in '1st Gen. Tacomas (1995-2004)' started by Strato, Mar 3, 2010.
  1. Mar 3, 2010 at 7:55 AM
    Strato
    Strato [OP] Active Member
    texas
    White regular cab
    Stock
    Has anyone installed the aftermarket catalytic converter and the 02 simulater from URD ?..i think im going to do that ...we dont have emissions test here just standard inspections...will it turn off the CEL codep0420..
    thanks
  2. Mar 3, 2010 at 7:59 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, it should turn that code off but you won't need an aftermarket CAT. Several members here have gone this route with success.
  3. Mar 3, 2010 at 8:06 AM
    Strato
    texas
    White regular cab
    Stock
    Thanks 98 can you recommend a place to buy the cat?
  4. Mar 3, 2010 at 9:28 AM
    98tacoma27
    Ben
    Not Beech Creek
    www.rockauto.com
    I have seen a few members here purchase a Walker aftermarket CAT from them and actually have the code go away.
    I would suggest one of the following options:
    A) purchase just the O2 sim. It will resolve your code issue
    B) purchase just the CAT and see if it resolves the code issue. If it doesn't, then purchase to O2 sim.
  5. Mar 7, 2010 at 5:35 PM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    agreed, I have the sim and works great. I had to get the sim because I bought a magnaflow high flow cat that was guranteed to be legal. It tripped a code in 2 weeks. DO NOT BUY A MAGNAFLOW CAT. My exhaust guy said all the ones he ever sold were brought back. If your alright not running one just get the sim. Just gut your current one.
