cat back exhaust trd or borla??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gator2011, Jul 9, 2011.
  1. Jul 9, 2011 at 2:24 PM
    gator2011
    gator2011 [OP] Member
    Zach
    Lake Norman, NC
    2011 TRD
    none yet. need advice
    so i want to make a decision about a cat back exhaust for my 2011 DC. TRD or BORLA????
    i like the sound of both by the clips online. the reason i am going full cat back and with one of these 2 exhausts is because the dealer says they wont void any warranty.
    so for the people that have one of the 2 or have heard please put your opinion in .
    thanks for your help.
  2. Jul 9, 2011 at 2:29 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    I run a borla.
    As said before many times, you wont see much of a difference in the performance of your vehicle. So go with whichever one sounds better to you.
    A few things ive noticed about the borla.
    No annoying drone while cruising down the highway.
    Nice overall tone in the lower RPM range.
    and she screams when you get on it.
    works for me :thumbsup:
    *edit*
    If you like them both equally, is one priced better? If so go with that. Both are quality catback systems.
  3. Jul 9, 2011 at 2:36 PM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    I have the TRD catback that comes with the TX Pro and it's pretty sweet. It isn't a muffler that screams to neighboring states that you are coming (which is the part I actually like) but it does let people closeby and yourself that you got something nice under the hood. Has a nice deep grumble when you put your foot down.
    Good luck choosing, I have not looked at Borla's, so I don't really have an extensive advice range.
  4. Jul 10, 2011 at 4:39 AM
    gator2011
    Zach
    Lake Norman, NC
    2011 TRD
    is the borla a one piece set up like the trd??
  5. Jul 10, 2011 at 5:48 PM
    gator2011
    Zach
    Lake Norman, NC
    2011 TRD
    any other insight?
  6. Jul 10, 2011 at 5:52 PM
    Maverick904
    Kameron
    Northeast Florida
    I think so...let me go take a peek real quick ahah.
    wait nvm...im pretty sure its 3 pieces
    tubing in front of muffler
    muffler
    and tubing/tip behind muffler
  7. Jul 10, 2011 at 6:02 PM
    gator2011
    Zach
    Lake Norman, NC
    2011 TRD
    thats what i thought ... have you had any excess noise or ratling from it being 3 piece>???
  8. Jul 10, 2011 at 6:18 PM
    Maverick904
    Kameron
    Northeast Florida
    nothing that I have noticed...the tail pipe is still as sturdy as it was the first day it was installed...no annoying bouncing around. Nothing has leaked. As long as you tighten everything down with the clamps everything should be fine.
    If you have any welding experience you can weld it all together when you get it on.. or if you want you can take it to a shop and I dont think they will charge too much to get a few welds put in.
  9. Jul 11, 2011 at 7:29 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    There will be no warranty problems from either a catback or a weld-in muffler, unless someone totally screws up the install. Don't listen to whoever told you otherwise, chances are they were trying to get a catback sale.
  10. Jul 11, 2011 at 7:41 AM
    Gene563
    Gene563 Well-Known Member
    Eugene
    Lanoka Harbor, NJ
    08 Double Cab, LB, TRD Sport
    TRD catback exhaust, Undercover hard tonneau, Vent visors, Husky liners, customized seat covers, front license plate bracket, rear suspension TSB, Eibach springs w 5100s@0, & General Grabber AT2 (265.70.17).
    I have the TRD unit and am very pleased with it.
    It was easy enough to install by myself in the driveway.
  11. Jul 12, 2011 at 6:30 PM
    gator2011
    Zach
    Lake Norman, NC
    2011 TRD
    thanks for all your opinions. i appreciate it . leaning more towards the TRD . i feel as if the sound will be good for me even down the road i plan on having this truck a long time. so not too loud but a perfect sound. im going to buy one tomorrow and install it after vacation. thanks guys
  12. Jul 12, 2011 at 6:33 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  13. Jul 12, 2011 at 6:35 PM
    ottomastiff
    ottomastiff Active Member
    Minneapolis
    2011 Taco
    TRD cai,s/c,catback, running boards. just a sub and a amp so far.
    Trd for moderate growl and a intact warranty
    Somewhere there is a compilation of exhaust sounds.
    Others may be louder and throatier
  14. Jul 12, 2011 at 9:13 PM
    CanisLupus
    Stokesdale | NC
    Yes, the TRD has a nice easy growl that doesn't get annoying when you drive it but still lets you know you got something nice under the hood.
    Good luck OP.
  15. Jan 5, 2012 at 10:36 AM
    benq
    benq Active Member
    Surprise, AZ
    2010 Doublecab, Shortbed, TRD Offroad
    Borla Turbo XL muffler TRD air filter
    Maverick904,
    Did you install the Borla catback yourself? Seems pretty straight forward. I've read removing the stock is more of a pain. I'm betting using jack stands will give me more room to work with.
    Any thoughts on the install?
    Ben
  16. Jan 5, 2012 at 10:50 AM
    benq
    benq Active Member
    Surprise, AZ
  17. Jan 5, 2012 at 10:52 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    why don't you ask your neighbors which exhaust system they will like better...they will be hearing it and thinking of you every time they hear it. I would rather keep a stock system and good relationships then be loud and obnoxious.
  18. Jan 5, 2012 at 11:02 AM
    kessler89
    kessler89 Well-Known Member
    OH
    12' Pro4x 6MT
    TBA
    neither, it'll sound stupid with anything but the stock
  19. Jan 5, 2012 at 11:19 AM
    RLDTACO
    RLDTACO Well-Known Member
    Bob
    Houston Tx.
    2010 DCLB PreRunner SR5
    Debadged,Tailgate theft mod,Extra D-rings,OEM bed mat,TRD exhaust, 5100 Billys@ 4 corners set@ 0 with Eibach springs, rear TSB springs.N-Fab tube Steps. TRD FJ SE wheels and Michelin LTX A/T 2's
    TRD catback.:thumbsup: Nice sound and easy to install in your driveway.
  20. Dec 1, 2012 at 6:49 PM
    trucknrv
    trucknrv Active Member
    Western MA
    22 TRD sport
    Snowsport plow with front receiver hitch, Access lorado tonneau cover, AVC ventshades, Covercraft seat covers, Husky floor mats, K-N filter, Hydraulic lift arms for hood, Factory black running boards, Direct cable from battery for jumper cables, Oil plug valve, Front anytime camera, Baja design fog lights, Bed mat, Borla exhaust with black tip, TRD skid plate along with stainless cat plate, 6 new speakers, Puddle lights, Floorwell lighting, Aftermarket heated seats, Interior LED lights, Swing tool box for the bed, Redarc brake controller, Blackout kit, Ceramic coated, Timbren load boosters, LED bed lights, Zprecision bigger cup holder, Drivers grab handle, License plates negated when in reverse, Sequential smoke mirror lights, Bumper step, 3rd brake light smoked out, Factory painted door edge guards, Door sill protectors, Mesa stick shift with additional buttons for the ECT, Extra 110V plug for the back seat and anytime 400 W plug for the bed, OTT tune, Protech for radio and dash film, Bigger radio knobs, LED hood light, Added LED strip backup light under the tailgate, AlphaRex tail lights. I am sure there is more but wife is starting to give me the side eye to add more! Like I heard they are not mods but it's a BUILD!
    Where do you get a TRD system? one piece? how much? Thanks Also..where can you hear a sound bite difference between borla and TRD?
