Cat back flange leak
Discussion in 'Performance and Tuning' started by UNDEAD1153, Oct 14, 2012.
  1. Oct 14, 2012 at 6:27 PM
    UNDEAD1153
    UNDEAD1153 [OP] Well-Known Member
    Weston
    Chattanooga Tennessee
    White 2011 TX Pro Double Cab
    Rough Country 6" lift, 17" XD Addicts, 315/70/17 Nitto Trail Grapplers, 6K HID's, Wet Okole's, Kenwood DD head unit, Custom Exhaust
    I've been searching forever and can't find an answer. I had some exhaust work done yesterday and had the exhaust cutout that I had kept open taken out completely. Now that it's all going through the muffler, I can tell its not the cutout that was leaking, it's the cat back flange. I had ran a few days with the whole exhaust off from that flame back. The guy at the exhaust shop said that I had a gasket leak. I take it off and the gasket is not there. He said it was spring loaded but I have no spring of any kind. I picked up a donut gasket and threw it on but it's still leaking. Any ideas on what I might be missing or might need to do to fix it? I've lost a noticeable amount of power and it has no sound really, just sounds like air blowing. I'm running a borla xr-1 muffler which is supposed to be pretty deep and fairly loud but I'm getting something more quiet than the TRD exhaust, what I'm guessing stock would sound like.
  2. Oct 14, 2012 at 6:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Take everything apart again, clean the matting surfaces really good, use some copper RTV, and apply a thin layer on the new gasket, and seating surfaces. Then reassemble, and torque bolts to spec.
  3. Oct 14, 2012 at 6:35 PM
    UNDEAD1153
    Weston
    Will do, thank ya Chris! You and whipper seem to always be the first to help and are usually right :thumbsup: well whipper usually shows up to give me a hard time and tell me I'm a stupid kid then offer advice haha :rolleyes::p
  4. Oct 15, 2012 at 5:39 AM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    If it still leaks after what Chris mentioned, then take some pictures and post up where the affected areas are. It will help us to better diagnose the problem. Again, only if it still leaks.
