Cat Converter
Discussion in '1st Gen. Tacomas (1995-2004)' started by dan476, Oct 9, 2013.
  1. Oct 9, 2013 at 6:49 AM
    dan476
    dan476 [OP] Well-Known Member
    On my 04 dbl cab I have 2 cat converters in line, the fwd one is rattling like a gypsy and needs to be replaced, but not throwing a code yet. Should I remove 2 cats and replace them with one aftermarket (magnaflow) cat? or should I just remove the fwd one and replace that one with aftermarket and keep the oem aft cat? I don't have any emissions to pass but I also don't want to straight pipe it. Thanks.
  2. Oct 9, 2013 at 6:58 AM
    icallhertaco11
    icallhertaco11 Well-Known Member
    Jamie
    Texas
    2008 Tacoma Prerunner v6
    Engage Long Travel 6 over with race spindles. 2.5x8 sway a ways wrapped in King Coils.
    What state are you in?
  3. Oct 9, 2013 at 7:46 AM
    dan476
    Im in Canada
  4. Oct 9, 2013 at 2:36 PM
    dan476
    anyone?
  5. Oct 9, 2013 at 5:57 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Gut the bad cat, install a URD Maf calibrator and call it good.
  6. Oct 9, 2013 at 6:18 PM
    dan476
    as i said I am not interested in straight piping it, now does anyone have an actual answer if I can replace just the rattling cat or replace both with just one aftermarket cat. Thanks
  7. Oct 9, 2013 at 9:28 PM
    MRBOND101
    MRBOND101 TTE
    Dylan
    Frisco, Texas
    16 TRD-OR AC
    Replace both with an aftermarket one. I had to do this as I was having problems with my CAT because I had previously cut my stock one in high school(young and dumb) out and put a cheap aftermarket cherry bomb on there. Later to found out the CEL issue was non related at all with my CAT from that day forward I always checked the codes..:eek: lol Anyway yes just buy an aftermarket one from rockauto you even get a 10% discount since your a TW member and call it good! :D Hope this helps!
    Best pic I could get of mine
