cat coverter and sensors replaced and still bad mpg
Discussion in 'Performance and Tuning' started by shotgunhooey, Mar 4, 2015.
  1. Mar 4, 2015 at 5:52 AM
    shotgunhooey
    shotgunhooey [OP] New Member
    john
    central ohio
    03 SR5
    I just had my both cat. converters and both sensors replace and it seems that I am still getting bad mpg. I was under the impression that the mpg would go back up to close to the 20 mpg. It seems that the mpg is staying around the 11 mpg. Should the mpg after replacements go back to normal? Could there be anything else that is dropping the mpg by half?
  2. Mar 4, 2015 at 5:59 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    You replaced those only because poor mpg? No CEL?
    I would start with basic maintenance like spark plugs and cleaning the maf.
  3. Mar 4, 2015 at 6:13 AM
    shotgunhooey
    john
    central ohio
    03 SR5
    Sorry, new to forum what is CEL? And I am not a a big wrencher. I am not familiar with the lingo. I had two diagnostics and both came back with cat errors. They replace o2 sensors ran dianogstics, error code came back again replaced cats. Just finished the cats.yesterday. Is the maf. the manifold?
  4. Mar 4, 2015 at 6:19 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    A CEL is a check engine light. I assume you had one of these on your dash before you replaced the converters?
    MAF is a mass air flow sensor that is located on the air intake before the throttle body.
  5. Mar 4, 2015 at 10:59 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Have you also checked your tire pressure lately? It might be way to low. That will suck out a huge amount of mpg.
    When is the last time that you changed your spark plugs?
    How many miles are on the truck?
  6. Mar 4, 2015 at 12:17 PM
    shotgunhooey
    john
    central ohio
    03 SR5
    I bought the truck used, so not sure. If I were to guess they have not been changed. That is one things that I am going to do in the next couple of weeks. I am not getting any loss of power or sputtering when driving. There is about 160k so the plugs are on the list. That I can do with help not in a shop. I am going to check the tire pressure this evening.
  7. Mar 4, 2015 at 12:24 PM
    shotgunhooey
    john
    central ohio
    03 SR5
    The CEL( thanks for the lingo) is off for the time being but the mpg drop was sudden. One day was 19 mpg the next I was watching the needle drop running 2100 rpms. Thought it was the extremely cold weather but it never recovered. I thank you guy first the advice I will start in on the list and let you know what happens
  8. Mar 4, 2015 at 12:33 PM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    first gen double cabs in 4cyl could get 20 mpg cruising on the highway but not as an average mpg very easily.
    I Assume yours is a V6 pre-runner?
    if you can squeeze 16-18 mpg be happy.
    But yes all the stuff that should have been done to your truck at 120k or so miles is if a 5VZ 3.4 Liter V6:
    Timing belt
    Water pump
    Check valve covers for leaks
    Check exhaust manifolds for leaks
    Replace O2 sensors front and rear
    I got 200k from my stock cats so not sure why yours fried out
    Clean throttle body, if possible have it taken off and fully cleaned both sides of butterfly
    check and replace all vacuum hoses
    Replace spark plugs with OEM dealer plugs for your vehicle only (no auto zone crap)
    Replace plug wires and check for compression since you have a shop that can do this have them make sure all cylinders are firing fine and have good compression
    Clean Mass air flow sensor on the intake tube with approved MAF cleaner only
    Replace air filter with stock OEM paper filter from dealer or napa gold for best filtration
    Tires properly inflated to spec pressure
    Replace rear differential fluid and check for metal shavings
    Replace transmission fluid check for shavings
    Inspect front and rear brake pads, rotors, lines ect for sticking or leaks.
    Sounds like a lot but preventative maintenance is cheaper than costly repairs and terrible mpgs.
  9. Mar 4, 2015 at 3:57 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Last sentence. Yup. :thumbsup:
    Correct me if I am wrong, but isn't the fuel filter replaceable on those year models? It should be replaced as well, regardless if it is easy or hard. 120k on the ticker, means that filter is saturated with contaminants.
  10. Mar 4, 2015 at 4:00 PM
    Balockay
    Balockay Well-Known Member
    Blake
    Cleburne, TX
    2017 4Runner TRD ORP
    Just look at the build thread
    Fuel filter is super easy to replace on first gens. Did mine at 120k and saw a small increase in mileage.
  11. Mar 4, 2015 at 4:04 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    ^^^^^There you go. Thank you sir. :thumbsup:
