Cat Delete? PO420 & PO430 Codes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by malahki, May 23, 2020.
  1. May 23, 2020 at 8:22 AM
    malahki
    malahki [OP] New Member
    2016 TRD OffRoad Acces Cab
    I have a 2016 offroad access cab with 100,000 miles. It has been getting the PO420 and PO430 codes. Local toyota dealer checked eveverything out and said everything was fine. They cleared the code and said if the codes came back I would need the Cats replaced. Of course the codes came back
    So the question is could it be something other then cats causing the codes? Bad O2 sensors?
    Or does anybody make software for doing a cat delete? Any other options or suggestions welcome
  2. May 23, 2020 at 8:54 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Its illegal but there are videos if you do search on these codes how to insert a resistor of a certain value on your downstream o2 sensor to fool the ecu to thinking your getting the correct fuel to air ratio. Did this to my tundra and it works till i got my new cats. Just make sure you erase the codes after.
  3. May 23, 2020 at 8:59 AM
    rocklobster2008
    rocklobster2008 Well-Known Member
    Jayson
    Fort Worth, TX
    2008 Red Tacoma TRD Off Road
    Brute Force Fab front bumper Dobinsons Snorkel 35" Nittos Bilstein 5100s ICON leaf springs RSI SmartCap Bed Replacement Diode Dynamics lighting Custom built morimoto headlights RCI full skid
    I've heard of people install spark plugs anti foulers on the O2 sensors with good luck and making these codes go away. I also have the P0430 coming and going with a state inspection coming up in June. So I've been debating it since it's a 6 dollar fix lol
  4. May 23, 2020 at 9:11 AM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    My first guess would be O2 sensors but that is a guess. Could be the Mass Air Flow sensor. Could be a control valve sticking open or shut. 100,000 miles the CATs should still be good. The O2 sensors should be a low price gamble Vs buying new CATs. I don't know if the CATS come with O2 sensors so you might have to buy new O2 sensors anyway. I just went through this on a 2004 Ranger.
  5. May 23, 2020 at 9:16 AM
    rocklobster2008
    Jayson
    Fort Worth, TX
  6. May 23, 2020 at 9:21 AM
    Dirt McGirk
    Dirt McGirk Well-Known Member
    Phoenix, AZ
    19 TRD OR 4X4
    I remember doing this to my first Civic probably 12-13 years ago.
  7. May 23, 2020 at 12:59 PM
    zoo truck
    None
    I had an engine check light around 180k come on indicating the cats were failing. Had already installed new upstream and downstream sensors awhile back due to open heaters. At the time of the failing cats i had to go through emission testing. Believe out or not the truck still passed anyways after temporarily doing this resistor mod, and erasing the codes so they wouldn't notice it.
