Cat heat shield not cutting it?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ScootsOFP, Sep 4, 2010.
  1. Sep 4, 2010 at 11:49 AM
    ScootsOFP
    ScootsOFP [OP] Well-Known Member
    Scoot
    Wisconsin
    03 PreRunner SR5/TRD
    deckplate, white LED gauges, fog light mod (Beau02 write up), Scion t1814 head unit
    I recently noticed that under my passenger side floormats (front and rear seats) had a good deal of condensation forming under while I drove. To the point where it was starting to smell musty in the cab.
    Looking under the truck it seems like the 2 cats are perfectly positioned to radiate tons of heat right where I have been getting condensation. The heat shields aren't rusted, so I'm confused about what might be causing the problem and how I can fix it.
    Ideas?
  2. Sep 4, 2010 at 11:57 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Odds are, Its AC condensation comming from the AC system. You should see a drain tube comming out of the fire wall (open the hood, or look under the vehicle). This tube may be plugged. You can run a peice of wire into it, to unblock whatever may be in it. OR, Use compressed air ( though you will want to do this from the cab). OR, It may have become disconnected. If the latter is the case, re connect.
  3. Sep 4, 2010 at 12:42 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I used a plastic zip 6 inch tie and inserted it into the drain to see if it were pluged.
  4. Sep 4, 2010 at 3:03 PM
    ScootsOFP
    Scoot
    Wisconsin
    I pulled the drain tube out from the firewall and it was clear, should I just use a wire or zip tie and try to clean further up in the drain pan, or what should my next move be?
  5. Sep 4, 2010 at 4:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Use a peice of good size wire. Fashion a hook on the end, and see if you can pul the juk out.
  6. Sep 4, 2010 at 6:02 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    Yep. Sounds like your AC drain is plugged. Chris has it spot on.
