Cat replacement, 2002 3.4
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoMac156, Aug 28, 2023.
  1. Aug 28, 2023 at 11:36 AM
    TacoMac156
    TacoMac156 [OP] Member
    2002 IMPULSE red tacoma 3.4 4x4 5spd
    Bilstein 5100 Deck plate mod URD short shift Magna flow cat back exhaust
    Just wanted to post on here and see if anyone has replaced the cats on a 2001 or newer 3.4, and what your experience/preferences were.
    Mine is a 02, and has the two cats; one right after the manifolds, and one slightly further down as it starts heading back to the muffler. Am I able to go to a single cat, or would I need to replace both? I do have a URD simulator that can be used if needed to cancel the CEL.
    My goal is to hopefully gain a little throat ier sound while not gaining an annoying highway drone and/or killing my MpG. I read plenty of back and forth on "the engine needs backpressure" and "no it doesn't, just cut them off and go race truck"... maybe a high flow cat is decent compromise?
    I have debated going completely straight thru( installing a "test pipe"?), and just welding a bung or using my URD simulator, just worried about the drone and having bad exhaust smell coming into the cab. I don't have to worry about emissions where I live, so thankfully I have a few options.
  2. Aug 28, 2023 at 12:33 PM
    02hilux
    Planet: EARTH
    The first question you'll have to ask yourself is, does your state require smog inspection?
  3. Aug 28, 2023 at 1:07 PM
    TacoMac156
    No, I am in WA and it was done away a few years ago now.
  4. Aug 31, 2023 at 5:04 AM
    02hilux
    Planet: EARTH
    If that's the case, do what is easiest or cheapest :thumbsup:
