CAT Scale Result. 1st timer.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by T8tjt, Aug 15, 2021.
  1. Aug 16, 2021 at 1:11 PM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    The Magnuson def helps when towing. I'm on stock gears with 33's and a blower, it was a nice change. The Magnuson really helps on hills and allows us to run in S5 of the flats. It has just enough added torque down low that it'll stay in S5 until you hit an incline. Seems to get better mpg sitting in 5th than wound up in 4th. I haven't ordered gears yet as I flip flop on what I think would actually work best.
    T8tjt[QUOTED][OP] likes this.
  2. Aug 16, 2021 at 1:19 PM
    T8tjt
    T8tjt [OP] Well-Known Member
    Tom
    Las Vegas, NV
    2017, Inferno TRD OffRoad 4x4
    Nitro 5.29, Eaton Front Locker, Bilstein 6112 & 5160, RXT leaf pack, Cooper 33’s, Magnuson, CSF Radiator. Stay Tuned.
    Did PowerStop extreme Z36 slotted and drilled rotors and pads a couple weeks ago.
  3. Aug 16, 2021 at 1:31 PM
    T8tjt
    Tom
    Las Vegas, NV
    As to the coolers, that’s has been handled by the factory tow package though their might be better after market options.
  4. Aug 16, 2021 at 2:09 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    i weighed my SR I4 Stock on certified scale
    not sure how U weighed.......................should have been 3 separate
    i guess the 6k is the taco....................the 4k the trailer ???????
    my front axle was 2400
    i would imagine a double cab V6 to be more
  5. Aug 16, 2021 at 2:48 PM
    T8tjt
    Tom
    Las Vegas, NV
    Yes first number truck, second trailer.
  6. Aug 16, 2021 at 2:52 PM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    Can’t be overweight if you don’t weigh it.
    :burnrubber:
  7. Aug 16, 2021 at 3:05 PM
    T8tjt
    Tom
    Las Vegas, NV
    I was telling the wife last night that given the ease to go over weight in the taco, that many of the overlanders we see crawling around here in the desert with steel front and rear numbers, winches, roof and bed adds a and top tents, that they have to be close or overweight themselves.
    davidstacoma likes this.
  8. Aug 16, 2021 at 3:08 PM
    JEFFRPM
    JEFFRPM Well-Known Member
    Jeff
    2018 inferno Double cab long bed 4x4
    17 x 8.5 KMC wheels, yokohama 285-70-17 geolander, 3" lift, 800 watts of alpine, leer shell, front & rear cloud cameras,
    Trailer....truck it dont matter it's the total of all sums that make up the max load, regarding the cooler issue ALL it was designed for is what's on the door sticker put on all the blowers, brakes, coolers, springs, yada yada the trans, axles, motor, steering were ONLY designed for so much that's it
    Just because a 1 ton Cummins set to 'KILL' can pull 36,000 lbs dont mean it will live long doing it
    Same goes for tacos
  9. Aug 16, 2021 at 3:14 PM
    T8tjt
    Tom
    Las Vegas, NV
    Yea, I’m looking forward to it.
  10. Aug 16, 2021 at 3:33 PM
    T8tjt
    Tom
    Las Vegas, NV
    No doubt. That’s said it’ll have to be for a year or two. On the plus side we only use it this way 3-4 times a year and our max travel is about 250 miles one way. So narrowing the weight issue shouldn’t be too hurtful.
  11. Aug 16, 2021 at 3:47 PM
    JEFFRPM
    Jeff
    One of my hunting friends was plowing his driveway at -30 below 3 winters ago & smoked his trans in less than 20 minutes from how fast the heat builds from tourqe converter slip (normal operating procedure) & if there is a way to lock the converter on a taco I don't know it BUT if you do find a way 5th & 6th gear both are overdrives that also build heat from gear multiplication I don't care if you do have 5:29's it still builds heat although not as fast as 3:90's (stock) with 33's or 35's
    It's only a matter of time on a stock motor standing on the loud peddle if blown or turbo even quicker
  12. Aug 16, 2021 at 4:05 PM
    T8tjt
    Tom
    Las Vegas, NV
    I understand.
    I tow in fourth and monitor temps on my scan gauge. I also don't allow the tranny to hunt generating even more heat. And I’m not racing anyone keeping the mph at higher levels come hell or high water on a grade.
    If I have a hill to climb while towing I manage the speed to keep the heat under control. I was going to pin the tranny thermostat before this trip but I forgot.
    I’ve got 25k miles on the truck, in the next few weeks it goes in for an oil change and I’m going to have them do the tranny fluid ahead of schedule. Might also have them throw a 170 thermostat in place of the 190 from the factory.
  13. Aug 16, 2021 at 4:25 PM
    JEFFRPM
    Jeff
    Both can't hurt I'd be cautious with the thermostat change due to the ECM might throw a check engine code from not getting up to what it thinks is normal operating temp & possibly over fueling thinking the engine is still cold.
  14. Aug 16, 2021 at 4:41 PM
    T8tjt
    Tom
    Las Vegas, NV
    Good point. I’lol ask the dealer.
  15. Aug 16, 2021 at 4:49 PM
    #35
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    heavy duty shackles and hangars are worth while if loaded with higher rate leafs.
  16. Aug 16, 2021 at 4:53 PM
    #36
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    For what it’s worth , I have mine pinned open during my tow season. Based on my pinned open temps, putting in a 170 tstat would seem to produce the same results. Also, the lower temps do not appear to bother the ECU. And, your dealer might not be a fan of either pinning or a lower opening temp tstat. I’d try pinning first.
  17. Aug 16, 2021 at 5:46 PM
    #37
    ROAD DOG
    FEW
    not a ‘ gotcha ‘ moment
    the manufactureres / engineers always keep a good % in their favor
    its good to stay in or near the established boundaries
    on tyre .......brakes.......frames + prudent speeds
    many drive as if it aint nuthin back there ........................
    in worst case scenarios disregard will work against U with catastrophic failures
    emergency room visits
    UNfavorable judgements with judge judy
    many whine & complain yet there are many that tow H E A V Y
    that are set up to tow H E A V Y
    that are Successful
    NOT jackknifed in a ditch with citations
  18. Aug 16, 2021 at 7:54 PM
    #38
    JEFFRPM
    Jeff
    All I know is you guys have brains so just be safe I've seen many tacos loaded with so much shit 5 feet off the ground ie tents, water cans, jacks, spare tires, you get the idea. There's no way all that lard that high & possibly over weight it HAS to handle like a shopping cart full of bowling balls in the corners let alone stopping all that shit.
  19. Aug 16, 2021 at 8:05 PM
    #39
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
  20. Aug 16, 2021 at 8:09 PM
    #40
    JEFFRPM
    Jeff
    Add steel bumpers with winches, fox 2.5's, rock sliders, a shitload of lighting, it would be perfect
    Oh yea question why it gets 4mpg
