Cat Shields Anchorage?
Discussion in 'Alaska' started by AKBorealis, May 24, 2022.
  1. May 24, 2022 at 6:24 AM
    AKBorealis
    AKBorealis [OP] Active Member
    22 MG Taco OR DCLB
    Anyone near Anchorage have or know of where one could pick one up and thoughts on DIY vs install? Thanks!
  2. May 24, 2022 at 10:50 AM
    Smokestacks
    Smokestacks Well-Known Member
    BayArea
    1996 3.4L 4x4 Tacoma extra cab MT.
    Eaton Truetac limited slip Bilstein 5100s struts set at 2” 5100s shocks Torch add a leaf B&M short throw shifter Hella h4 headlights Warn front hitch Curt rear hitch Sony DSX-GS900 Deck Custic 1000watt amp Alumpro 10” sub Lund Steel Gullwing tool box Broadway rearview mirror Weather tech window deflectors
    Do you have smog checks in Alaska? Can’t steal something that’s not there. Could weld a flange on the exhaust for easy swap between cat and pipe when or if needed. Everything ive seen for sale will just add a couple mins and require a couple more tools for the thief. If your talking about a heat shield I’ve seen ppl use these cooking trays haha.
  3. May 31, 2022 at 7:21 PM
    ColdTaco49
    ColdTaco49 Has a well-used member
    Fairbanks, Alaska
    2022 TRD Off Road DCLB Lunar Rock
    As far as I’ve found, nobody up here keeps them in stock. In typical alaska fashion they can order it for you for more than it would cost to buy it yourself and get it shipped yourself. I did find a couple online vendors that shipped to Alaska.
    Regarding the install, it looks pretty straightforward, might be worth tackling yourself
