catalyctic converter
Discussion in '4 Cylinder' started by kutoy, Jul 16, 2015.
  1. Jul 16, 2015 at 8:22 AM
    kutoy
    kutoy [OP] Member
    2011 Tacoma TRD Sports
    My check engine light came on my '02 Tacoma 2.4 with a code of P0420. Brought it to a dealer
    and they did a test and according to them both my front and rear catalyctic converters
    needs to be replaced. Can both catalyctic converters be bad at the same time? They are charging me an arm and a leg.
  2. Jul 16, 2015 at 8:55 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I have no idea what kind of converter that is. #spellcheck.
    The dealer is sort of right but a lot wrong. The code references inefficient catalytic converters. The cause isn't the cats, that's just the result of the cause. I'll bet your cats are fine. #meow
    You might try checking your fuel pressure and fuel trims. I had the same code (2nd gen) and after lots of digging it turned out to be a weak/clogged fuel pump.
