Catalytic Converter Acid Wash
Discussion in '2nd Gen. Tacomas (2005-2015)' started by libagui, Sep 29, 2012.
  1. Oct 1, 2012 at 7:57 PM
    #41
    gmcuajo
    gmcuajo Well-Known Member
    Puerto Rico
    Just -sylvania ZXE on head & fog lights -the tires
    Go to eBay, buy two catcons of 3" (2.5", or whatever the size needed). Go to a muffler shop and get them install them. Or just go to the muffler shop and get them install new cats on your truck. This will cost you $50 each plus $50 installation. Maybe some more...
    Take your old cats and recycle them. Maybe you get $5 for each.
    #41
  2. Oct 2, 2012 at 12:51 AM
    #42
    libagui
    libagui [OP] Well-Known Member
    Dominican Republic
    05 tacoma prerunner
    Bilsteins 5100 set at .085 Rear custom 1" add a leaf 265/70 R17 tires. Custom made aluminum tonneau cover with bike rack. 4x4 conversion with 4Runner transfer case.
    Don't you know those converters won't work on ours Tacoma trucks?. You could use those to replace the secondary converters, wich are not monitored by sensors. If this experiment doesn't work the way to go are new original cats, or a high quality magnaflow or equivalent...$1000 each.
    Anyway, a experiment is not going to kill the truck, if it result to be useless you can always say " I knew from the beginning it were going to be a lost of time, and then be a totally demonstrated wiseman"
    #42
  3. Oct 2, 2012 at 3:35 AM
    #43
    libagui
    Dominican Republic
    05 tacoma prerunner
    Thanks for the good wishes..!
  4. Oct 2, 2012 at 4:40 AM
    #44
    aw113sgte
    aw113sgte Well-Known Member
    Right, because it only dissolves once with water, after that it breaks the laws of chemistry and physics and becomes dissoluble. In that case I have some dissoluble sugar for you to buy if you're interested (as well as a bridge) :p
  5. Oct 2, 2012 at 5:09 AM
    #45
    medusa1066
    medusa1066 Well-Known Member
    Jonathan
    Morgantown, WV
    2007 4x4 TRD Sport
    If you don't rinse the cat off with purified water, there will be recrystallization of salts, which might do very bad things in the presence of palladium and very high temperatures. The safest thing to do is skip the baking soda and do a purified water rinse. (OK, really the safest thing is buy a new cat, but I am subbed anyways)
  6. Oct 2, 2012 at 5:10 AM
    #46
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    So then, why doesn't the calcium that deposits on the showerhead, why doesn't it dissolve With water anymore?
  7. Oct 2, 2012 at 5:22 AM
    #47
    medusa1066
    Jonathan
    Morgantown, WV
    2007 4x4 TRD Sport
    http://en.wikipedia.org/wiki/Solubility_chart
    Behold the Laws of Dissolubility ;)
    [EDIT: Calcium Carbonate is one of many shower head salts]
  8. Oct 2, 2012 at 8:19 AM
    #48
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Just incase you still stand by your sugar bridge claim read what he said.
  9. Oct 2, 2012 at 10:08 AM
    #49
    gmcuajo
    Puerto Rico
    Why not? Do tacomas have wideband O2 sensors? It doesn't matter? Is the same... The first sensor read what's going out of the engine, and the second sensor read what's going after the cat, what should be cleaner and not oscillate like the first one...
    $1000 each for catalytic converters! Wow! I think you want to say $100 each.
  10. Oct 2, 2012 at 10:13 AM
    #50
    Portaparty2
    Portaparty2 "I know each one of you, like I know my own smell"
    Santa Poco
    12 PreRunner Sport
    Debadged, Magnaflow exhaust, Avid step bars, 5100's
  11. Oct 2, 2012 at 10:14 AM
    #51
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    The dealer quoted me $1300 to do the Driver side upper cat. Where are you getting your numbers from? Use the search button or create another thread asking for opinions on non-Toyota Cats.
    or from the internet
    Toyota Part:
    MANIFOLD ASSY, EXHAU
    Part NO.: 17140-0P100
  12. Oct 2, 2012 at 10:30 AM
    #52
    gmcuajo
    Puerto Rico
    Really a $1300 for a catalytic!
    Why tacomas can't use "magnaflow" cat converter (or normal)? Please talk more about that... I just want to know, learn. That's the purpose...
  13. Oct 2, 2012 at 11:15 AM
    #53
    Sandman614
    Tim
    '06 SR5 Off Road
    If you don't believe me call the dealer and tell them you are out of warranty and are getting a p0420 or p0430 CEL. Use the search button or create another thread asking for opinions on non-Toyota Cats.
  14. Oct 2, 2012 at 11:21 AM
    #54
    libagui
    Dominican Republic
    05 tacoma prerunner
    The software in the ECM decides when a catalytic Is good or not. Something has Toyota done in their cats that make exhaust gases different in a way sensors notice it, and that my friend, Is beyond my knowledge.
  15. Oct 2, 2012 at 11:36 AM
    #55
    gmcuajo
    Puerto Rico
    Don't help at all!
  16. Oct 2, 2012 at 11:37 AM
    #56
    gmcuajo
    Puerto Rico
    The acid wash works or not?
  17. Oct 2, 2012 at 12:03 PM
    #57
    Sandman614
    Tim
    '06 SR5 Off Road
    I'm not going to hold your hand like a 2 year old... ignored
  18. Oct 2, 2012 at 12:08 PM
    #58
    libagui
    Dominican Republic
    05 tacoma prerunner
    Did you read the article at the begining of the thread..?.. it Is supposed to work. In my case, I will wait at least 200 miles without a check engine to have a conclusion..!
  19. Oct 2, 2012 at 12:11 PM
    #59
    Sandman614
    Tim
    '06 SR5 Off Road
    He doesn't seem to want to help himself.
  20. Oct 2, 2012 at 12:15 PM
    #60
    gmcuajo
    Puerto Rico
    I want to know your own results... And what is the special about tacoma's catalytics?
