catalytic converter - camry
Discussion in 'Technical Chat' started by ramonortiz55, May 21, 2014.
  1. May 21, 2014 at 10:05 AM
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Anyone ever had to replace a catalytic converter?
    My check engine light went on in my 2003 camry and the dealer told me it is the catalytic converter:mad:
  2. May 21, 2014 at 10:16 AM
    finecamaro69
    finecamaro69 Member
    Charlotte, NC
    06 TRD sport 4WD
    2" spacer Suspension lift, Dakar Leafs
    I changed one out on a 1996 Camry LE 4 cylinder. It wasn't too hard once I got the bolts loose. Just had to drop the exhaust pipe behind it and take the bolts off where the converter connects to the header. We bought a 2007 and the engine bay basically has the same setup as the 1996 so I would assume that it would be the same for a 2003. The converter I bought was a cheap aftermarket replacement and it fixed the check engine light.
  3. May 21, 2014 at 10:21 AM
    ramonortiz55
    Ramon
    Texas
    stock
    so you think what the dealer does is reliable diagnosis?
    those things are expensive, and i would like to see if anything else could set off the check engine light before i replace the converter.
  4. May 21, 2014 at 10:38 AM
    finecamaro69
    finecamaro69 Member
    Charlotte, NC
    06 TRD sport 4WD
    You can always take it to an Advance Auto or Autozone for a free check engine light code check. They check the codes for free and let you know what sensor is showing a problem. The converter that I bought was less than $200. Just looked on autopartswwarehouse.com and the front ones are just over $300 for a bolt on replacement for the 2003. They also now combine the header and number 1 converter into one part so that would be why it's more expensive.
  5. May 22, 2014 at 9:50 AM
    ZEROPILOT
    ZEROPILOT Can't re-MEMBER
    ED
    SUNRISE,FLORIDA
    09 2.7 XTRA CAB 5 SPEED
    LARGER WHEELS. DIFFERENT STEREO. PUSH BAR. TAILGATE EXTENDER. WIPER MOD. TPMS LIGHT DELETE MOD.
    +1 Yes. Be prepared to cut off, bang out and replace the mounting bolts. Just in case.
  6. May 22, 2014 at 6:58 PM
    KnoxTac0713
    KnoxTac0713 Well-Known Member
    Justin
    Knoxville, TN
    13 DCSB SR5 4x4 Barcelona Red
    Bilstein 6112, rear 2.0 Icon VS shocks, TRD Black SEMA wheels, 255/80/17 Cooper ST Maxx, SOS Rear bumper, SOS bolt on sliders,TRD skid plate, derped badges, 15% tint, color matched oem grille, lamin-x amber fog covers, TRD cat-back exhaust, Tacoma bed mat, Tonno-pro trifold, Depo black tail lights, front tow hook w/ D shackle, Wheeler's Superbumps rear, Wheeler's 1 inch block rear, Custom Car Grills mesh grill insert, light bar in lower valence
    Wife's 02 threw the bad cat code. I was told I had to replace the whole manifold. Try to get a rebuilt one but they were out. Couple years later still not replaced. Engine light only comes on on long trips.
