catalytic converter HELP! please
Discussion in '4 Cylinder' started by rs50fox, Jul 4, 2010.
  1. Jul 4, 2010 at 12:18 AM
    rs50fox
    rs50fox [OP] Active Member
    USA
    So a few days ago I had a shop weld my magnaflow muffler on I drove around a bit. Then got home looking under my truck to take another look at the welds and I see the 1st cat glowing red close to the back is what it looked like to me. I dont know if it did this before the magnaflw muffler or not. My check engine light is not on and I used a scan tool and eveything thing seemed normal according to the snap on modis.
    another question I have has anyone ever check the temp of thier catalytic converter?
    thanks for any help or tips
  2. Jul 4, 2010 at 7:05 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Cats run very hot. THats their job. For them to glow red, is not un common.
  3. Jul 6, 2010 at 6:18 AM
    tacosuprem
    tacosuprem Well-Known Member
    Florida
    4x4
    clogged
  4. Jul 6, 2010 at 9:42 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    The check engine light would be on if it was clogged due to the reduced backpresure.
    Catalytic converters have to reach a very high operating temperature to activate the platinum used as the catalyst. It is not uncommon for a truck idling in high grass to start a fire.
    Be careful in dry conditions.
  5. Jul 6, 2010 at 9:55 AM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    There is supposed to be a heat sheild on it. If not it was likely removed since it started buzzing. (happened to me in my last 2 vehicles)
  6. Jul 16, 2010 at 7:39 PM
    rs50fox
    USA
    thanks, it seems to do it most when I get on it for awhile or when the heat or a/c on. anyone ever look at thier 1st cat after a long drive?
