Catalytic Converter Protection | MillerCAT Cat Shield
Discussion in 'MillerCAT' started by MillerCATCorp, Nov 1, 2021.
  1. Dec 10, 2021 at 2:23 PM
    #61
    DadBodTaco
    DadBodTaco Member
    Bay Area, CA
    2021 TRD Off Road
    So I don't have any fancy measuring tools. To me, it appears to be around 1.75 mm thick for the Stainless Steel one I have. I attached a picture, but note the camera angle I think makes it look a little thinner. Hope this helps, but hopefully the manufacturer replies with the exact specs.
    MAYNIAC likes this.
  2. Dec 21, 2021 at 2:13 PM
    #62
    MillerCATCorp
    MillerCATCorp [OP] Well-Known Member Vendor
    MillerCAT
    Toyota Tacoma Cat Shield Manufacturer
    Our Aluminum Cat Shield is 14 gauge and our 304 Stainless Steel Cat Shield is 16 gauge.
  3. Dec 21, 2021 at 3:32 PM
    #63
    MillerCATCorp
    MillerCAT
    Shoot us a DM! We'd be more than happy to help you out!
  4. Dec 21, 2021 at 3:39 PM
    #64
    MillerCATCorp
    MillerCAT
    Malvolio likes this.
  5. Dec 21, 2021 at 3:56 PM
    #65
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
  6. Feb 2, 2022 at 1:58 PM
    #66
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    Any word on '05-15 4x4 version?
  7. Feb 8, 2022 at 9:20 AM
    #67
    6gearsofv6fury
    6gearsofv6fury Gasoline > Electricity
    Rancho Cordova, CA
    '22 TRD Sport DCSB manual, Super White, Build Date 3/29/22
    None yet.....
    It looks like if you have a skid plate, you can remove it without having to do anything with the shield, correct? Having to remove both to do an oil change would be a chore.
  8. Feb 10, 2022 at 12:54 PM
    #68
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I’d like to know as well. Frame is pretty much similar if not the same
  9. Feb 16, 2022 at 12:50 PM
    #69
    MillerCATCorp
    MillerCAT
  10. Feb 16, 2022 at 12:55 PM
    #70
    iltdi
    iltdi Well-Known Member
    Rockford, IL
    2019 SR5 2.7 I4
  11. Feb 16, 2022 at 1:01 PM
    #71
    LiquidArrogance
    LiquidArrogance Well-Known Member
    Streets of Bakersfield
    2021 SSM Sport 4x4
    MillerCATCorp[OP] likes this.
  12. Feb 16, 2022 at 2:30 PM
    #72
    iltdi
    Rockford, IL
    2019 SR5 2.7 I4
  13. Feb 16, 2022 at 2:37 PM
    #73
    MillerCATCorp
    MillerCAT
    We're working on a 2.7L 4WD Cat Shield but it won't be available for some time. Unfortunately, our 2.7L 2WD cannot be modified to fit the 2.7L 4WD as the undercarriage is completely different. You can contact us at info@millercat.com to be added to our waitlist.
  14. Feb 16, 2022 at 2:41 PM
    #74
    LiquidArrogance
    2021 SSM Sport 4x4
    My bad. Reading is hard. :D
  15. Feb 16, 2022 at 2:46 PM
    #75
    MillerCATCorp
    MillerCAT
    You're good. You helped to clarify for us :cheers:
  16. Feb 17, 2022 at 12:53 PM
    #76
    Foushee
    Foushee Well-Known Member
    Sean
    Texas
    2018 Inferno TRD OR DCSB MT
    Just getting started.
    @MillerCATCorp can this be installed without lifting the truck (2018 TRD OR)?
  17. Feb 17, 2022 at 1:31 PM
    #77
    MillerCATCorp
    MillerCAT
    You most likely could install this Cat Shield without lifting the truck but it'll definitely be a tight squeeze.
    Foushee[QUOTED] likes this.
  18. Feb 17, 2022 at 1:59 PM
    #78
    MAYNIAC
    MAYNIAC Well-Known Member
    Bay Area
    2018 TRD Sport DCLB
    I believe so. @DadBodTaco can confirm?
  19. Feb 17, 2022 at 2:23 PM
    #79
    MillerCATCorp
    MillerCAT
    We're working on it. Send an email to info@millercat.com to join the waitlist.
    essjay[QUOTED] likes this.
  20. Feb 17, 2022 at 2:24 PM
    #80
    MillerCATCorp
    MillerCAT
    Yes, there is no interference from the Cat Shield when changing your oil.
    gr8-wrx likes this.
